headlight adjuster stripped
Old Jul 19, 2008 | 07:58 PM
gen3fan's Avatar
I'm sure this is a common problem, and I was wondering if anyone had a fix they'd like to share. There are two adjustment screws on the back of each lens designed for aiming your headlights. One is this thumbwheel kind of thing, and the other is just a very long screw or bolt. Both of these enter into the back, which is plastic, and you guessed it, on a 15 year old car the plastic threads are pretty much stripped down to nothing with very little ability for adjustment. This wouldn't have been a problem except I had to replace the lens (with a used part) and now I have to re-aim it. Any tips?
Old Jul 20, 2008 | 01:12 AM
CMax03's Avatar
go to the boneyard!
Old Jul 20, 2008 | 02:06 AM
jonmandude's Avatar
picture of the part? I may have saved it when I did my E36's
Old Jul 20, 2008 | 02:30 AM
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by CMax03
go to the boneyard!
yup
Old Jul 20, 2008 | 07:19 AM
gen3fan's Avatar
1) working on the picture
2) boneyard is where I got the first replacement lens, which I had to replace again with one from a parts car (I had hoped to keep it intact for now), and that one had the same problem
I'm working on a possible solution, maybe involving some JB Weld or something. I just hate to have to spend too much time on such a ridiculous little problem.
Old Jul 20, 2008 | 07:32 AM
3g94MaxGXE's Avatar
Maybe once I go back to school I should make some metal adjusting screws on the lathe and sell them here.
Old Aug 1, 2008 | 03:24 PM
gen3fan's Avatar
sorry for the delay, buddy crashed his bike (pretty nasty). anyhow, I figured out a solution, simple but it works-
backside of lens and bracket. note adjust on upper left & lower right
15 years of corrosion. small wonder there was a problem.
'thread cutting nuts' from loews. works good because it grips the worn out corroded threads on the bolt.
Old Aug 1, 2008 | 03:37 PM
jonmandude's Avatar
I have one of those in perfect condition. PM me
Old Aug 1, 2008 | 03:39 PM
gen3fan's Avatar
take off the 2 metal caps from back of the lens, replace the stripped out plastic threaded insert with the threaded screw.
reassembled, straightened the beam, got my inspection sticker. on to the next project- ripping out the bose & puttin a decent stereo in
Old Aug 1, 2008 | 03:41 PM
gen3fan's Avatar
I'm sorry, one of what?
Old Aug 1, 2008 | 04:47 PM
BenStoked's Avatar
Jesus was a Zombie.
kudos on the problem solving!
Old Aug 1, 2008 | 05:30 PM
300zmax's Avatar
thats a great fix, McGyver would be proud! seriously great fix!
Old Aug 2, 2008 | 02:14 AM
jonmandude's Avatar
One of the adjusters that is stripped. I removed them when I did my E36's and stuck them in a box.
Old Aug 2, 2008 | 01:15 PM
gen3fan's Avatar
thanks for the compliments. you might have noticed traces of jb weld in the photos. at first I was trying to use that to keep everything in place, but it was taking too long to set so I wiped it off and started over. but everything stays pretty tight in there as long as you get the screws torqued in good.
jonmandude, PM sent
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
