dead temp gauge?
Old Jul 24, 2008 | 05:22 AM
300zmax's Avatar
dead temp gauge?
Has anyone had any issues with their temp gauge, i have a 91 with 205k on the motor. the temp gauge is turning on and off. i check the temp sensor and it was working fine while the gauge was acting up. is this a wiring issue anyone came across or am i lucky one. tap it and turns on (sometimes). can i replace it with another nissan temp gauge or do the gauges not come apart?
Old Jul 24, 2008 | 06:17 AM
internetautomar's Avatar
mod or sell?
if a tap affects the gauge, then the gauge is the problem.
Old Jul 24, 2008 | 06:20 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
you can individually replace odometer, trip meter, odometer drive motor, speedometer, tachometer, and the combo of fuel/temp. 91se or 91gxe? GXE i can provide the gauge... SE i'm using the only one i have that works (temp needle on my other SE cluster went bad the same way yours did)
Old Jul 24, 2008 | 06:38 AM
300zmax's Avatar
GXE, will GXEs of other years work?
Old Jul 24, 2008 | 07:59 AM
300zmax's Avatar
can i buy SE gauges new or do i have to JY dive for them
Old Jul 24, 2008 | 08:36 AM
everything is cross-compatible. it's just a matter of mismatching the font if you cross the 91/92 border. 89-91 has a different font from 92-94
Old Jul 24, 2008 | 01:03 PM
BenStoked's Avatar
Jesus was a Zombie.
you could buy new gauges, but they would come from nissan...
best bet would be a jy. or another member parting out.
just fyi, all gauges can be swapped with no modification (except the digital clusters, requires harness modifications)
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
