Got The 1993 SE, Now To Fix Things
Old Aug 5, 2008 | 07:46 PM
ProphetVG30E's Avatar
-im not having too much luck with search with ANY of these things, so im going to just list the couple of problems and see if any of you guys have been in the same scenarios.
-cruise control inoperable
-radio DOES NOT WORK anymore. it did when i installed it, then just SHUT OFF.
-Speedometer doesnt operate, but everything else does. PLUS: the whole cluster came off an 89-91 SE, so that may be a factor.
any help appreciated
Old Aug 5, 2008 | 08:06 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
1) more info needed. does the left-hand switch work and just not the wheel switches? or not the one down on the left either?
2) i don't know crap about audio. sorry. maybe bad wires burned the fuse or something.
3) cluster type doesn't matter. just pick up one you like from an ORGer or the boneyard.
Old Aug 5, 2008 | 09:11 PM
burhan92SE's Avatar
1) Same question as Cap or u can pull one out from junkyard....
2) u need to see if ur radios ground is properly connected or no....i had the same problem so wat i did is that pulled my aftermarket player and saw that ground is touching then not touching lol....so i fixed the ground and pushed the harness a lil but and never had problem after that...plus u could check ur fuse...
3)it could be bad Speedometer sensor or bad wiring....
Old Aug 5, 2008 | 09:47 PM
hmm if the VSS doesn't work then it WON'T let you into cruise....
question for OP: does the odometer still roll?
Old Aug 5, 2008 | 10:23 PM
burhan92SE's Avatar
Old Aug 6, 2008 | 03:20 AM
-The switch on the steering wheel for the Cruise Control.
-Odometer still rolls
-will rewire radio today
Old Aug 6, 2008 | 06:22 AM
internetautomar's Avatar
mod or sell?
you need a new cluster, that will fix the speedo issue.
the max radio gets ground through the antenna and most aftermarket radios can work with that.
does your horn work?
is your airbag light on?
you may have a bad clock spring.
Old Aug 6, 2008 | 06:53 AM
-radio issue solved. (Fuse)
-sure its not the speed sensor that needs to be cleaned or replaced??
-horn works
-air bag light does not come on.
would the 89-91 se w/o air bag light ever work???? i kno when i put one in my GXE, the overdrive light worked fine.
Old Aug 6, 2008 | 06:58 AM
mod or sell?
-horn works
good
100% positive
good
good
I don't know if an 89-91 cluster would even have an airbag light as an option.
no matter what you need a cluster, start there and get one with a good airbag light. if the light comes on, then we know that you likely need the clock spring. if not then it's wire tracing time!
Old Aug 6, 2008 | 07:01 AM
-horn works
if odometer rolls, speed sensor works.
wrt the airbag light... you can crack the cluster open and swap items around as necessary. what i'd suggest is to get the JY cluster and put the tachometer and speedometer into it (leaving fuel/temp and odometer put) and also you can use that time to swap the extra light in for the airbag. If need be you can swap the films with light labels on them to accomodate adding that light.
Old Aug 6, 2008 | 07:35 AM
cant i just get the new cluster and swap the odometer if mileage isnt similar or close??
Old Aug 6, 2008 | 07:37 AM
yea you could. it's just as easy either way i suppose. fuel/temp comes out in order to get the odometer loose.
Old Aug 6, 2008 | 08:58 AM
just a basic screw in, screw out,right???
Old Aug 6, 2008 | 09:45 AM
yeah. phillips head.. nuthin fancy.
Old Aug 7, 2008 | 09:02 AM
iight
Old Aug 7, 2008 | 10:23 AM
burhan92SE's Avatar
so i can jus take out the cluster by opening those screws around it? i dont have to mess with whole dash?
Old Aug 7, 2008 | 12:42 PM
oh. yea you have to take the dash out. i thought you meant if there were special tools involved in actually working with the cluster once it's out. but most of the dash is phillips head too, actually.
Old Aug 7, 2008 | 06:15 PM
burhan92SE's Avatar
can u show me the locations of the screws that holds the dash cuz i dont wanna go to junkyard and wonder around for screws plus its SO HOT here nowa days....and its hard to work wen SUN is right on ur head and plus in car it gets hotter...jus a favor
edit:i m doing that digital cluster swap so i dont wanna end up breaking something cuz i get exhausted wen i m workin in hot place and plus if it doesnt come out then .....
Old Aug 7, 2008 | 06:53 PM
-what i would do (AT THE JUNKYARD) is just rip stuff apart till you get what you need.
plus, its only like 12 screws total, you'll see them, and you'll kno when
Old Aug 8, 2008 | 05:59 AM
-okay proceeding w/ the restoring processes, my hvac controls jakked up on me, so in gonna need to remove em before i suffocate myself on the highway (STUCK ON HEAT! OUCH)
Old Aug 9, 2008 | 02:28 PM
anyone.................
Old Aug 9, 2008 | 02:34 PM
BenStoked's Avatar
Jesus was a Zombie.
I had a similar problem when I got my car. had to figure out where the cable went to to manually close the vent valve.
also, make sure the actuator is moving in the engine compartment. if it's staying open, could cause some extra warmth when you dont want it.
Old Aug 9, 2008 | 07:10 PM
1992maximase30's Avatar
the 89-91 did'nt have an airbag, it was optional in 92 but i belive they made it standard in 93.
Old Aug 9, 2008 | 07:19 PM
-jus popped the dash open getiin to the back of the unit,now, ITS ICEEEEE COLDDDD. jus gotta change either the setting or the unit come fall/winter, lmao.
-yea, i do think airbags had to be standard in all cars after 93, am i right???
Old Aug 9, 2008 | 07:53 PM
mod or sell?
<snip>
yes drivers was standard in 93.
alot of vehicles went to dual airbags for 94.
Old Aug 17, 2008 | 01:17 PM
-just an update, i changed the cluster to a 92-94 se cluster. no problems.
Old Aug 17, 2008 | 01:25 PM
BenStoked's Avatar
Jesus was a Zombie.
hey, prophet, when I had my problem, it went away after working that flap open and closed for a while. maybe if you just work it, it would get the movement it needs so you can use the lever. well, it worked for me, anyway.
Old Aug 17, 2008 | 03:40 PM
what the hvac controls??? im not worried about that. i "broke" it so it could spit out some a/c
Old Aug 21, 2008 | 09:03 PM
-Another Update. Cluster Changed And Working, But Still No Cruise Control. Havent Diagnosed It Yet. Im Guessin A Little More Than A Fuse.
-Tinting Windows, And Customizing My Grille. LookOut For That
Old Aug 21, 2008 | 09:12 PM
cruise issue is prolly just a bad steering wheel switch then. got another ABS wheel handy?
Old Aug 24, 2008 | 04:54 PM
nope, and i dont plan on swapping steering wheels. not a big problem.
next on the list, front end body work, to lead to e36 headlights.
Mar 12, 2020 12:06 AM
chernandez1278
Sep 16, 2015 01:18 PM
tardrex
Sep 11, 2015 07:35 PM
slowlifer
Sep 8, 2015 05:53 AM
