Need help with Frame question
Old Aug 16, 2008 | 09:22 AM
guitarpro_1st's Avatar
My 92 maxima is still going strong and i need to know one part on the car....i was told that these cars where a uni-body so that the parts of the frame can be removed and replace if need be....i notice on the pass. side of the car where the control arm connects to the frame with to big bolts is starting to rust away i was just wondering what that piece is called and if anyone know where you can buy it? heres a website that i think i found what it is
http://www.courtesyparts.com/betasit...1724_1746.html
i believe it is part 74802N
any help would be good thanks
Old Aug 16, 2008 | 12:43 PM
jonmandude's Avatar
Without a picture it would be difficult for any of us to tell you if that is correct or not. But from your description I would guess that that is the correct part.
Old Aug 16, 2008 | 07:52 PM
burhan92SE's Avatar
i think thats called SUBFRAME....
Old Aug 17, 2008 | 06:09 AM
internetautomar's Avatar
mod or sell?
based on the illustration, that is a frame rail and if yours is rusted so bad that it needs replacing then expect to find alot of other rust elsewhere on the car. once you find rust, it's only a matter of time before it eats everything to the point of it being unsafe and illogical to fix.
Personally if the control arm mounting area is rusted, I would replace the car. the costs involved are not worth it IMO
Old Aug 17, 2008 | 02:56 PM
sleepyvg30e's Avatar
my frame rail is rusted i scraped and sprayed it but theres no rust near the control arm (mechanic double checked for me)should i consider serious bodywork before the car gets totaled from it? or do i have some time if i maintain it properly?
Old Sep 10, 2008 | 07:09 PM
Jordan91SE's Avatar
You can use something called rubber undercoating. 3M makes this along with many other companies. It basically adds a rubber coating to the chassis and helps prevent rust in certain areas of the car. I have used this product on every car I have owned and it works great.
REDinLV
Aug 15, 2024 12:30 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
