Gas door doesnt open
Old Sep 2, 2008 | 03:22 PM
jdmjunky's Avatar
I here it clicking, it sound like it wants to open,its holding in place .But when i try to open it from inside the car it doesnt open. I have to kinda pry it open by hand.Any suggestions!
Old Sep 2, 2008 | 05:58 PM
vernk's Avatar
if you pull back the carpet in the trunk you should be able to reach the release I think you pull the white plastic thing and it should open then adjust so it works and give it some lube and some on the hing might be a good idea and check the spring thing (a little piece of metal that pushes it open) and make sure everything is lining up right
Old Sep 10, 2008 | 04:10 PM
Jordan91SE's Avatar
Also, check to see if you can pull the cable without the handle. If you can, then see if the cable is just binding and that might be the reason you can't open the fuel door. The cables are easy to replace and not that expensive. When you get the carpet pulled back, see if the springs need a little grease. They might just be a little stiff and need a little grease to help.
ef9
Sep 29, 2015 11:29 PM
JoshG
51
Sep 21, 2015 10:41 PM
johnaschon
Sep 14, 2015 04:29 PM
dcam0326
Sep 7, 2015 07:26 AM
