Reset digital touch entry ( GXE ONLY )
Old Sep 2, 2008 | 07:31 PM
burhan92SE's Avatar
as u guys know i jus bought a GXE and it is fully loaded with sonar suspension and blah blah lol......i donoo how to reset digital touch entry and the owner i bought from cant be reached and donoo where he is...can u guys help me out? cuz the link in stickes has been expired.....i don have the code for it and i cant enter the car cuz the lock is broken....thanks guys
Old Sep 2, 2008 | 09:30 PM
92max4me's Avatar
Here's the link
Old Sep 2, 2008 | 10:24 PM
burhan92SE's Avatar
thanks alot bro....it helped me alot....
Resetting 89-94 Maxima keyless-entry
What you have to do is remove the glovebox from the car, (which is a couple of screws and a twist of the glovebox light) After you have done this, you will see a silver box on the right-hand side, if you are looking into the glovebox. There are, I believe, 2 screws holding that box in. Remove those screws and you will come to find out that this is your keyless-entry control module...On this box there are several numbers engraved into it...your master code is the number with an "s" in front of it...so for example s7577331, it should have 7 numbers in the master code (WRITE IT DOWN!!!). Then just put this number into your key-pad and it should beep for about 10 seconds, then put in a number combo you'd like and vuala, you've reset your keypad and put in your new code...(use the master code whenever you want to change the code on the door) Hope this helps, and good luck!
Old Sep 2, 2008 | 10:34 PM
burhan92SE's Avatar
i think this thread should move to General Maintenance cuz the link there for resetting digital touch entry doesnt work anymore for some reason
Old Sep 3, 2008 | 04:08 PM
92max4me's Avatar
I agree... and no prob
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Garrettz459
Sep 28, 2015 02:50 PM
