VG 3rd gen owners - get more power!
Old Oct 5, 2008 | 06:15 PM
  #41
Maxpwer's Avatar
No turbo, no care!
Originally Posted by mrkanda
If you go with the 3.5L displacement what would be the bore and stroke measurements. The reason I ask is because I wonder if you can use the pistons from a 3.5L VQ. If so, that would make it very easy to swap in performance ready-made pistons.
Well unless you change the crank, stoke will be unaffected. The VQ35 uses a 81.4mm stroke vs the VGs 83mm, which means the using the VQ35 95.5mm piston size will give you a displacement slightly above 3.5L.
I dont have all the details, but its highly unlikely that these pistons will fit on VG/VE rods without modification.
stevesmax
Dec 17, 2020 11:57 AM
maxinout93
Aug 20, 2015 02:17 AM
WeetoddA32
Aug 16, 2015 12:45 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
