Cleaning MAF sensor with CRC
Old Sep 21, 2008 | 06:06 PM
xnos's Avatar
Hey guys,
I got the CRC MAF sensor cleaner and I was wondering if their is any tutorials on how to properly clean the MAF sensor on my 93 max.
thanks
Old Sep 21, 2008 | 06:30 PM
ProphetVG30E's Avatar
-take it out, put a napkin under it, spray it about 20 times, let it dry, reinstall, and 'ello mpg's.
Old Sep 21, 2008 | 07:10 PM
Greeny's Avatar
¯\(°_o)/¯
20 times??
Just remove the maf from the car, set it on the ground, spray the little "light bulb filament" looking thing in the middle of the maf housing with the spray for about 5-10 seconds,reinstall, done
Old Sep 21, 2008 | 07:33 PM
Pearl93VE's Avatar
I can has?
MAF cleaner is the exact same as CRC's electrical contact cleaner btw. Only you can get the electrical contact from Home Depot for like $2 cheaper.
Old Sep 21, 2008 | 07:51 PM
1993-VG30E-GXE's Avatar
Are you serious? The QD Electronic Cleaner can is much cheaper through my industrial supplier. Where did you find out this information?
Old Sep 21, 2008 | 08:14 PM
burhan92SE's Avatar
so u can clean electrical connections like harnesses and connectors with MAF cleaner then?
Old Sep 21, 2008 | 08:15 PM
burhan92SE's Avatar
Originally Posted by xnos
Hey guys,
thanks
do as greeny said hes right....not 20 times lol....
Old Sep 22, 2008 | 06:01 AM
internetautomar's Avatar
mod or sell?
upon what are you basing this information?
Old Sep 22, 2008 | 07:18 PM
i was exgatterating when i said '20'.
Old Sep 22, 2008 | 07:28 PM
Matt93SE's Avatar
STFU n00b!
What is the MAF made from? It's a small thermistor mounted on the end of a shaft holding it in place in the middle of a plastic tube. It's a simple electrical component used in all kinds of parts- automotive and other- for the last 30 years. Cleaning it with electrical parts cleaner will not hurt it at all.
Old Sep 22, 2008 | 07:39 PM
burhan92SE's Avatar
really? and i was arguing wit auto parts store guy dat u can only clean MAF with its special Cleaner not electrical cleaner...ahh.. oh well thanks for letting us know....i m gonna buy electrical parts cleaner nex time its cheaper
Old Sep 23, 2008 | 08:53 AM
mod or sell?
I was asking to know if he had seen the chemical formula or something.
Old Sep 23, 2008 | 11:16 AM
Darkwing48's Avatar
Yeah, there's always that one Hydrogen Atom that separates water from heavy water and then BOOM.
So a themistor... really? That's all?
Old Sep 23, 2008 | 03:25 PM
Pearl93VE's Avatar
I can has?
Nope, haven't checked out the chemical formula, but was told by more than one mechanic that it's the exact same thing renamed to jack up the price. Before I asked anyone, there was a tutorial over on FordF150.net on how to clean an MAF that he specified to use electrical contact cleaner, always used it on all my vehicles and never had a problem.
Old Sep 23, 2008 | 03:30 PM
Matt93SE's Avatar
STFU n00b!
yup...
the electronics inside the maf simply feed a current through the thing and cause it to maintain a constant temperature. the amount of current required to do that is directly related to the amount of air flowing across it (thus cooling it)...
so the MAF measures the current and translates that to an airflow number based on the air temperature/density, and calibrated to the size of the MAF housing.
pretty simple trick actually. been used for years in many industries to measure flow of any fluid that's non-conductive.
-ReLLiK-
Apr 29, 2016 06:25 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
