Jerking at 2000 RPM
Old Sep 23, 2008 | 05:58 PM
Amillyon's Avatar
Jerking at 2000 RPM
I'm getting intermitten jerking at 2000 RPM and I can't accelerate unless I drop below 2000 RPM. I disonnected the MAF to see what would would happen (stalling ) and the Check engine light didn't even come on.....
Last edited by Matt93SE; Sep 24, 2008 at 06:29 AM. Reason: RPM not RPMs. get it right!
Old Sep 23, 2008 | 06:03 PM
Hectic's Avatar
New MAF
Old Sep 23, 2008 | 06:06 PM
Pearl93VE's Avatar
I can has?
Originally Posted by Amillyon
I'm getting intermitten jerking at 2000 RPMs and I can't accelerate unless I drop below 2000 RPM'S. I disonnected the MAF to see what would would happen (stalling ) and the Check engine light didn't even come on.....
Can you accelerate past 2000 RPM's? Or does it stop there and jerk. Disconnecting the MAF won't immediately throw a code, but if you can tell no difference in the engine's performance when it is disconnected it is probably the culprit. If you can accelerate past 2000 RPM's, when in gear or idle, that could be a number of things. If might be worth checking resistance on your injectors and coolant temperature sensor. Also, is the car in good tune? (Spark plugs, wires, (or Coils if you have a VE), air filter, fuel filter, etc.?) Report back.
ColombianMax's Avatar
Get a MAF
Old Sep 23, 2008 | 06:27 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
bad maf. replace it.
Old Sep 23, 2008 | 06:50 PM
Amillyon's Avatar
I forgot to mention the the temp gauge also shows no temp after driving for a while then perks up to normal....this definitely is more than likely bad because the connection is secure.
Old Sep 23, 2008 | 07:06 PM
the temp needle is an isolated system. there are 2 temp sensors. one for ECU, and one JUST for the gauge. see if this is happening to the gauge one:
if that is happening then it's the sensor, if not, probably the gauge.
Old Sep 24, 2008 | 12:00 AM
burhan92SE's Avatar
ya for ur gauge needle its the sensor which cap showing in his pic...check wiring or anything u could find bad about that sensor.....and for ur jerking its 90% chances are BAD MAF.....try to change with someone else who owns 3rd gen and see if it gets better then u will know its MAF but if it still does the same thing then u will save ur self alot of money....and i have a MAF sitting around doing ntn but getting dust on it....PM me for more detailes....
Old Sep 24, 2008 | 09:27 AM
if you wanna come by my place i have a spare
Old Sep 24, 2008 | 09:40 AM
maxima63's Avatar
make sure your intake hose going from the maf to the intake has no cracks or leaks, i had a mx-6 that had that problem and it was because it had a crack in the rubber after the maf and letting unmetered air in after the maf, i used some electrical tape to fix the crack(i know ghetto) but it worked perfectly.
TKHanson
Nov 24, 2018 01:39 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
