CMPS trouble
Old Sep 26, 2008 | 02:39 PM
whattingh's Avatar
CMPS trouble
I have a little intermittent miss when the car is cold and at around 1200rpm it it runs ruff. As the car warms up it basically goes away. They other day I pull the codes for first time. Got 11(Camshaft position sensor) and 21(ignition signal circuit). I cleared it and drove a few blocks and check for codes again. This time it was clean(55). Today I check for codes again and 11 is back.
I check the CMPS connector and it is clean. I added a test ground wire to the distributor and no difference. I open the distributor to see if the rotor plate of the CMPS is not dusty for some reason. It was clean but have a few minor scratches on it.(straight lines across) Have no idea how it got there. None of the slots looks damaged.
Could this scratches cause a malfunction or is the sensor on it's why out?
Is the sensor repairable?
I have in the last week replaced distributor cap, spark plugs, oil, filters
injectors read between 11.7-12.1ohm
Old Sep 26, 2008 | 02:53 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like new dizzy time. the sensor itself may be intermittently failing, internally.
Old Sep 27, 2008 | 10:37 PM
CMax03's Avatar
yeah that's possible! Spray the wheel and optical pick up with some circuit board cleaner! By the way, what condition is your timing belt in? You may what to inspect it and the distributor helical drive gear for security and ensure that the drive pin isn't loose or worn allowing the drive gear to move, causing your timing to jump around....
Old Sep 28, 2008 | 12:03 AM
whattingh's Avatar
My timing belt was replaced about 6000miles ago. I have check the timing and it is pretty stable, moving maybe 1 or 2 degrees.
Thanks for the replies so far.
14GmMax
59
Aug 4, 2019 11:26 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
