Quick ? about foglights
Old Sep 23, 2008 | 05:44 AM
swowlinc's Avatar
1993 SE
Can out oem foglights stand HID? Also whats the bulb size in there?
Old Sep 23, 2008 | 06:32 AM
BenStoked's Avatar
Jesus was a Zombie.
the housing may, but I am not so sure about other drivers...
Old Sep 23, 2008 | 08:58 AM
coolsun's Avatar
i am thinking about this too, the h3c ones fit, but i dont know if they are good for the wiring harness.
Old Sep 23, 2008 | 01:51 PM
DanNY's Avatar
Ad·min·is·tra·tor
H3 and it needs to be the short H3 HID.
Old Sep 23, 2008 | 03:35 PM
coolsun's Avatar
yeah the short ones are h3c
Old Sep 23, 2008 | 06:08 PM
CMax03's Avatar
Sorry but that's incorrect! The H3's with the power tail have a different plug than the H3C's. The H3C's have 2 small pins on the end they will not work on the OEM 3rd Gen foglights! Now as for an HID bulb the foglight assy is to shallow due to the HID bulb being longer than the halogen H3. I measured it when I installed HID H3's in my 5.5 Gen. I'll see if I can find the dimensions for you and reply later ok......
Old Sep 23, 2008 | 07:53 PM
coolsun's Avatar
i want to hid mines but im not sure now... they doo look similar and we can also not use the foglights ground right?
its something like this??? http://www.retro-solutions.com/h3minibulbkits.html
Old Sep 23, 2008 | 08:41 PM
swowlinc's Avatar
1993 SE
alright cool, thx for the input
Old Sep 23, 2008 | 08:59 PM
coolsun's Avatar
ok your right the h3cs have 2 pins sorry
Old Sep 26, 2008 | 10:34 PM
CMax03's Avatar
yeah that's the smallest HID bulb I've seen in H3' it will work as a HiD for sure , since the housing on the 3rd gen are so shallow!
Old Sep 26, 2008 | 10:38 PM
CMax03's Avatar
Well, that is in HID form, so yes it will have 2 leads not 2 pins as the halogen bulb has. I stated that the halogen H3C could not be used on an OEM 3rd gen due to the harness difference when compared to a halogen H3.....but the HID's are a goer!!!!
Old Sep 27, 2008 | 10:54 AM
coolsun's Avatar
you think i can splice up the wires and add a harness?
Old Sep 27, 2008 | 11:13 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
if it's just as simple as same-wires-different-connector then yea that should work just fine
Old Sep 27, 2008 | 10:29 PM
CMax03's Avatar
If you're going the HID route...you can hit the junkyard for two 3rd gen connectors from the foglight harness to the chassis harness and use those for your HID so you can be plug N play! I never chop up my vehicle's wiring harness cause when you sell it; Or try to sell it you don't want the buyer being hesitant or worried about getting some chopped P.O.S. with all kinds of wiring gremlins. I was able to use my original( damaged) 5.5 gen foglight harness connectors on my 5.5 gen when I converted my fogs to HID! I solder spliced/heat shrinked the connector to the HID harness so I can be plug-N-play, still maintain it's weather proof OEM design, and perform maintenance quickly-N-hassle free (bulb change, etc...)...good luck...matching headlights and fogs are sexy!!!!
Old Sep 28, 2008 | 12:06 AM
coolsun's Avatar
well im not letting my 3rd gen go until it dies, so i guess i would save the hassel on finding another 3rd gen with fogs, thanks for the advice though
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
