Power Locks
Old Oct 11, 2008 | 09:07 AM
BruceM99's Avatar
Power Locks
My power locks stopped working yesterday and now i have to lock and unlock each door manually... i know its not the main control cluster on the drivers side door because i just replaced that about a month ago. can any one help?
Old Oct 11, 2008 | 04:04 PM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/3rd-generat...t-working.html
Old Oct 11, 2008 | 06:11 PM
burhan92SE's Avatar
i doubt its ur door lock timer unit and there is a connection in there which cracks sometimes and then u have to solder that to make locks work....wen u press unlock/lock button on ur dirver side door do u hear clicking sound under ur dash?
Old Oct 12, 2008 | 01:44 AM
Greeny's Avatar
¯\(°_o)/¯
Old Oct 12, 2008 | 11:24 AM
BruceM99's Avatar
All the sudden they started working again today, this has happened in the past too. And there is no clicking when i press the button when they don't work.
Old Oct 12, 2008 | 12:38 PM
Hectic's Avatar
Well if it happens again, keep in mind that the door lock timer doesn't even exist from 89-91.
Old Oct 12, 2008 | 02:32 PM
BruceM99's Avatar
mines a 92 GXE
Old Oct 12, 2008 | 03:16 PM
burhan92SE's Avatar
oh if u dont hear clicking sound then i guess its ur driver side main buttons control unit...u will have to open that and see wats wrong or change it to another one from JY....
Old Oct 12, 2008 | 03:28 PM
Greeny's Avatar
¯\(°_o)/¯
Are you daft???
He said he already replaced the main d-side switch.
Old Oct 12, 2008 | 05:06 PM
burhan92SE's Avatar
oh mah bad greeny lol.....BruceM99 u still have to open ur D-side main switch and check the voltages in the harness....it might be power supply problem....u wil need a multimeter for that...download FSM and power lock is in body section of FSM for volatges specifications..
http://www.phatg20.net/component/opt...leinfo/id,140/
Old Nov 8, 2008 | 08:33 AM
mymaxima's Avatar
Power door lock timer
Just what needs to be Soldered on the timer? A wire or prong? Does the Door Lock Timer unplug from the other unit so I can work on it out of the car?
Old Nov 8, 2008 | 10:07 AM
Wiking's Avatar
The cold solder points, component to pcb 'contacts' (Printed Circuit Board). Unplug, take it home... After cleaning just quick heat/melt every point.
Old Nov 26, 2008 | 01:54 PM
MAX92SE's Avatar
my power locks went out to they wont work for about a day then they will work all of a sudden then sooner or later they wont work again idk whats wrong when not working i hear a click when i push the button but nothing happens.
Old Nov 26, 2008 | 08:00 PM
burhan92SE's Avatar
i cant go out ritenow and take a pic of door lock timer cuz its freezing out here and plus its night but i can point u in FSM where it is so u can have an idea where it is but ya u will have to unbolt the cover under the steering column to get to the door lock timer...pull the harness out gentley and then u will have to unclip the cover of the timer and gently pull the door lock timer circuit borad out...take it in and find where the crack is and solder it and install it back and u r done....
Old Nov 28, 2008 | 02:21 PM
Ridemywideglide's Avatar
Couple questions...
My power locks work fine, as does the keypad, but I recently replaced the driver door switches due to power window buttons only going down.
Before, I could turn the key (or push/pull the lock) and all doors would follow suit. Now they don't.. If I use button, or keypad, they all lock/unlock, but the auto feature (or whatever it's called) no longer works.
Also, if I lock the driver door on exit then close, it unlocks when the door shuts. I have to use key or pad after it's closed...?? Supposed to be this way?
Old Nov 28, 2008 | 02:33 PM
Greeny's Avatar
¯\(°_o)/¯
Zee door lock timer iz bad..
Remove, resolder the bad(brown looking) connections, or replace with a known good used unit.
Old Nov 28, 2008 | 02:52 PM
Thanks greeny.. I didn't think it would be the same problem since mine still work..
Old Nov 28, 2008 | 03:00 PM
Greeny's Avatar
¯\(°_o)/¯
The DLT is a weird little unit, in some cases, it will stop all locking operations, then in some others, just partial controls fail or go heywire.
My wifes gxe done the same as yours, i just resolded the bad connections inside the unit, it's worked fine since.
Old Nov 28, 2008 | 03:21 PM
Looking at that pic it must be up under the dash to the right (from seat) of the steering wheel??? Does the dash have to come apart to get to it?
While trying to preztel myself in there to have a look, I find this...
No remotes tho..
on edit: Nevermind.. I've got it out..
Old Nov 28, 2008 | 03:58 PM
Greeny's Avatar
¯\(°_o)/¯
No remotes tho..
You do realize that is not the factory door lock timer?
Old Nov 28, 2008 | 04:17 PM
Hahahaha.. yea... That's aftermarket... I saw the sticker reminding mechanics of the remote start on the radiator support. Just thought it was taken out since remotes didn't come with the car.
I found the timer on the front of the ASCD <sp> controller... I pulled it apart and melted all the solder bumps, but no change. And the locks still worked with the unit removed...
Old Nov 28, 2008 | 04:25 PM
Greeny's Avatar
¯\(°_o)/¯
Ya know, i just realized you have a 90 model, right?
if so, according to past information, your car does not have a door lock timer, all your locking/unlocking functions are controlled by the master door switch.
Old Nov 28, 2008 | 06:11 PM
Well shizzle... that explains why it didn't work..
Guess I'll be finding another master switch.. lol
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
