Is there a quick ckeck for no heat????
Old Nov 13, 2001 | 06:53 AM
SCOTTFISH's Avatar
A co-worker of mine has a 90 Se and today he has noticed that there seems to be no heat. This is a first. Can anyone tell me if there is a quick check on this problem or should it be taken to the shop? A quick response would be appreciated.
Scott
Old Nov 13, 2001 | 07:30 AM
HoJo's Avatar
Re: Is there a quick ckeck for no heat????
Does the fan come on when you turn on the heat?
Old Nov 13, 2001 | 07:33 AM
SCOTTFISH's Avatar
Re: Re: Is there a quick ckeck for no heat????
He didn't say. I would assume the fan blows, but never heats up. I know this information is limited and it is sometimes hard to diagnose problems with limited info. What is your thoughts?
Old Nov 13, 2001 | 07:44 AM
blackandwhite's Avatar
To them I'm like an idol
Re: Re: Re: Is there a quick ckeck for no heat????
Check the vacuum hoses that connect to the heater control valve. It is located under the hood, in the center, at the firewall, at the top.
Old Nov 13, 2001 | 08:08 AM
Chris Gregg's Avatar
Get Off My Lawn
Just this past Friday I had to remove my heater motor and clean it out. There was an excessive amount of leaves and dirt in it, I even removed the motor cover and cleaned it out. Works fine now, quiter too! I did have to remove the glove box, but that was easy and was done in about 10 minutes in a parking lot.
Old Nov 13, 2001 | 11:17 PM
NZ Max's Avatar
Re: Re: Re: Re: Is there a quick ckeck for no heat????
My 3rd Gen did this when I had it. The Heater core also burst at 100000km and spewed alover the ecu and fried it. I sold it after that.
__________________
'96 Nissan Cefiro VQ25DE 140kw (190hp)
My Ignore List:
KCTYPHOON
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
