Power Steering is acting wierd...
Old Nov 13, 2001 | 04:24 PM
DaBoxSE's Avatar
Everytime I cut the wheel all the way to the left it makes a LOUD vibration. It did it only once in a while when I first got the car, but now its all the time! What could be doing this? My PS fluid seems level too. Do I need to replace the pump? I hope not cuz I heard its like $250. And I want to put the $$ to a Y-Pipe!
Old Nov 13, 2001 | 04:28 PM
Gamezilla's Avatar
I think...
It may be your stut or springs, but I'm not sure.
Old Nov 14, 2001 | 05:34 AM
DaBoxSE's Avatar
Hmm, I dont think thats the problem, sounds like a motor problem or something. Plus, it only does it the first time you cut the wheel. It wont do it again until after to wait a while or when you first start up the car.
Old Nov 14, 2001 | 07:11 AM
Steindawg
I have a similar problem with mine, usually occurs when I am stopped or moving fairly slow and cut the wheel all of the way. I have been told its just the pump getting old, and it can't move the fluid quite like it used to, so when you are pretty still it has to work harder to move the fluid. I am not sure how much to replace it, I haven't checked into that yet.
Old Nov 14, 2001 | 09:06 AM
Bman's Avatar
Old power steering pumps start making noise when they age. Can't remember if this means the pump itself is going or the belt just needs replacing (american cars sometimes had separate belt). I'll have to consult a service manual tonight because I've had the same noise once in a while at low/no speed too.
Old Nov 16, 2001 | 04:58 AM
DaBoxSE's Avatar
That sounds like the problem. I am just concerned about it cuz I didnt know if was a serious problem. Bman, let me know what you dig up man.
Old Nov 16, 2001 | 08:40 AM
Bman's Avatar
oops! I forgot all about it! I'll try to remember tonight.
Old Nov 17, 2001 | 03:36 PM
bklyngirl89's Avatar
I had the same problem, but it shut off when it was turned. It was the pressure hose 100 for the hose, it was leaking bad. Now its fine, but if i cut it too fast when the car is cold it vibrates. Check if u have a leak somewhere..
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
ColdCananda
Sep 20, 2015 10:45 PM
