Need Speed Sensor help Please....
Loosen the lug nuts on one wheel.
Jack up the front of your car.
Place it on jack stands.
Take the wheel off.
Turn the steering wheel to the opposite side of the wheel you just took off, so that you can see behind the brake.
It's a small round magnetic piece held in place with a bolt or two. There should be a wire going to it as well.
Hope this helps. Currently I need the left front sensor, so if anyone wants to sell one to me.....thanks.
Take the wheel off.
Jack up the front.
Place the car on jackstands.
Take off the wheel.
Turn the steering wheel to the side opposite to the wheel you just took off, so that you can see behind the brake.
It is a small round magnet (looks like 5 quarters stacked on top of each other) held in by a bolt or two. There should be a wire going into it too.
Hope this helps. Currently, I need a left front sensor, so if anyone wants to sell me one......thanks.
Jack up the front.
Take off the wheel.
Originally posted by MAX420
I thought it was located on top of the transmission ?
Speed sensor (transducer) is located on the top of the transmission. Standing on the drivers side of the car (LHS) it is almost directly below the oil filter. It has one screw / bolt holding it in and has a loom coming out of it.
What Ghostmax and JDwyer2821 are referring to are the ABS sensors. Two different things.
Brent.
Brent.
Brent.
Brent.
sdotcarter
Sep 2, 2015 09:53 PM
