Clutch replacement... IDK
Old Jan 16, 2009 | 08:00 AM
swowlinc's Avatar
1993 SE
Hmm , I went to start the car yesterday and after it warmed up a lil I tried to drive away and it wouldny go into gear. I tried a couple more times and then I got into first, second and finally third. I parked the car and when I went out this morning ,I cant get into any gear at all. I looked at the clutch fluid and its not full, but more than half full. Also my clutch pedal stays on the floor when I press it unless I pull it back out myself. This started last night. Can a clutch go bad overnight or do I need to adjust the cable, or could this be happening because of too little clutch fluid in the reservoir?
If I need to replace my clutch then I will get the Fidanza also. I just want to make sure I need to replace the clutch before I shell out $500. Thank God there's a GD going on for the fidanza for $335 shipped, and I see exedy clutch on Ebay for like $140 shipped. Im kinda hoping for a package deal from somewhere if I can get it.
Old Jan 16, 2009 | 08:09 AM
Greeny's Avatar
¯\(°_o)/¯
You don't have a "clutch cable" you have a hydraulic clutch system. You either have a bad clutch master cylinder, or a bad clutch slave cylinder, or maybe(long shot)a leak in the lines somewhere.
Old Jan 16, 2009 | 08:10 AM
BenStoked's Avatar
Jesus was a Zombie.
what do you mean, "wont go into gear"? can you get it in a gear no problem with the engine off? is it grinding if you try to force it?
Old Jan 16, 2009 | 08:40 AM
swowlinc's Avatar
1993 SE
hmmm I havent tried to go in gear with the car off
i will try . brb
Old Jan 16, 2009 | 08:46 AM
swowlinc's Avatar
1993 SE
goes into every gear except reverse without the engine running
Old Jan 16, 2009 | 09:15 AM
505max94se's Avatar
i bet it's the slave cylinder
Old Jan 16, 2009 | 09:20 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
it'll go into reverse if you had the car on a hill and let it roll an inch or two while pushing the shifter into reverse. but anyhow, that indicates that your clutch just isn't letting go, which supports greeny's post.
user 11122324
42
Jul 18, 2022 03:35 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
carlosvq30
Sep 26, 2015 09:44 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
