Rear wheel bearings exist?
Old Jan 22, 2009 | 07:43 AM
Cinnamint's Avatar
I'm swapping out the GXE rear drums from some rear disc brake action. So to plan ahead I trolled around and starting finding all the wear parts that I might need to replace (IE: brake line, E-brake cables, discs...so on). So I got to wheel bearings, and oddly enough nobody sells them.
Whats up with that? Do the rear bearings never wear out on our cars?
Old Jan 22, 2009 | 07:51 AM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/3rd-generat...ring-help.html
http://www.courtesyparts.com/maxima-...1700_1703.html
DanNY's Avatar
Ad·min·is·tra·tor
you have to buy the entire hub assembly...can't just get the bearing.
the hub unbolts from the knuckle.
Old Jan 22, 2009 | 07:58 AM
BenStoked's Avatar
Jesus was a Zombie.
wait, according to the pic in greeny's link, the strut assembly(?) is one part number for all six years, as well as disk/drum applications. I was under the impression that it was different for drums and disks, as well as some disks differed from one year to the next (thinking about caped's rear bbk thread) am I nutzo, or is Courtesy incorrect?
Old Jan 22, 2009 | 08:10 AM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/3rd-generat...onversion.html
Does anyone search this forum anymore??
Old Jan 22, 2009 | 08:28 AM
BenStoked's Avatar
Jesus was a Zombie.
thats what I thought... yes, I searched (after I posted), but that doesnt mean that somebody was wrong. Heck,
Old Jan 22, 2009 | 09:26 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
those numbers are just reference numbers
http://www.courtesyparts.com/kb_sear....php?keywords=[55302K]+\(j30&cPath=1610_1611_1700_1704
that's the actual breakdown of the different rear struts. but still none of those list real nissan part #s
Old Jan 22, 2009 | 03:21 PM
Cinnamint's Avatar
I understand the whole rear hub part. It just seems to be a dealer only part ($118+ shipping). I can not find a single parts store that has them.
I just find it quite odd that there is nobody making rear hubs/bearing for our cars.
Old Jan 22, 2009 | 03:27 PM
Greeny's Avatar
¯\(°_o)/¯
The rear bearing failure rate is like next to nill, hence the "unavailability" of the part aftermarket. My 340k SE still has the original rear bearings, still just as tight/smooth as new..
Old Jan 22, 2009 | 05:22 PM
1993-VG30E-GXE's Avatar
Green - is it possible to service those rear or front GXE bearings by cleaning then re-greasing, even if they aren't acting up yet?
Old Jan 22, 2009 | 05:28 PM
Greeny's Avatar
¯\(°_o)/¯
They are sealed/unserviceable bearings...replacement is the only option if bad.
Old Jan 23, 2009 | 05:54 AM
Matt93SE's Avatar
STFU n00b!
I'm not wrong. (I'm never wrong! :P )
See that 1/2" additional shoulder on the strut on the right? that's there to make the bracket for the caliper fit without rubbing the wheel bearing and put everything at the right spacing/offset.
I figured that out 10 years ago when I did the first rear disc swap.
Old Jan 23, 2009 | 07:49 AM
BenStoked's Avatar
Jesus was a Zombie.
[img]http://blehmco.com/faq/rear_disc_conversion/Dcp01044.jpg[img]
I didn't say you were wrong, just somebody.
caped also said there was a difference between (89-90) and (91-94) disc brakes. I was merely pointing out that teh linky above to courtesy was weird.
god, I hate buying parts online (or even looking at them) most of the time.
Old Jan 23, 2009 | 11:10 AM
yea. 89-90 had a long bracket and a stubby torquemember. 91-94 had short brackets and longer torqemembers. That's why you can take the 89-90 bracket with 91-94 torqmemembers (and their calipers and ebrake cables) to make the extra just-over-an-inch clearance for z31 rotors. but take away the brake hardware and all disc brake strut casings are the same. the damping/rebound for the VE vs VGSE vs disc-eqipped GXE might be different, but the casing, hub, bearing, etc are all the same
Old Mar 11, 2016 | 03:21 PM
shoneyzz's Avatar
help need one of these 1989 rhd
i need one as damage its a 1989 model abs auto
Old Mar 11, 2016 | 09:42 PM
DanNY's Avatar
Ad·min·is·tra·tor
the FS/WTB section is in the classifieds, not in the general discussion area.
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
