Why no hot air?
Old Jan 27, 2009 | 06:36 PM
  #41
internetautomar's Avatar
mod or sell?
the trick of raising the front end is used on vehicles that have a point in the cooling system higher than the radiator filler neck.
We've used it on vans when needed.
Old Jan 27, 2009 | 06:41 PM
  #42
ImmaSquashYou's Avatar
call me a newb...but what exactly is the radiator filler neck??? i've always filled the radiator through the radiator cap....n filled the reservoir....is the rad cap the rad filler neck??? i haven't really looked into the 3rd gen as much....so you can rag on me if you'd like.....
Old Jan 27, 2009 | 06:42 PM
  #43
mod or sell?
the rad cap is on the filler neck.
Old Jan 27, 2009 | 06:43 PM
  #44
ahhhhh....ok........thanks!!!!!
Old Jan 27, 2009 | 06:46 PM
  #45
Greeny's Avatar
¯\(°_o)/¯
Old Jan 27, 2009 | 07:14 PM
  #46
Originally Posted by Greeny
i know..i deserved it...i'll ban myself for a few hours..
Old Jan 27, 2009 | 07:16 PM
  #47
Greeny's Avatar
¯\(°_o)/¯
hit up my itrader before you go..
Old Jan 27, 2009 | 10:32 PM
  #48
PMAX08's Avatar
so i picked up a used coolant overflow assembly at the wrecker today off a gxe with the abs, put it all on, of course i wasnt expecting heat or anything just cus of this, i put in about an inch and a half of coolant in the res, the rad is still topped up when i checked it, still getting hardly any heat, only when driving, so i guess i should do the thermostat again and bleed the **** out of it with the car on an incline? if that dont work ill start it on fire and enjoy the heat...lol..im kidding i really do love this car..lol
Old Jan 27, 2009 | 11:06 PM
  #49
i don't think that its you're thermostat. they're usually made to fail open...and in case it is failed and stucked closed...there should be no coolant going to the engine and will overheat...which would give you heat while your idling. If you are stuck open....you should get more heat while you're not moving since the engine will get cooler while you move because it will be air cooled. at least thats what happened in the 4th gen....
Do you see your engine temp guage go up or down while you drive and while you get heat and then no heat?? since you're getting heat while you move..the temperature gauge should be in the middle (normal) temp. If you are not getting heat, means that the temperature should be below the middle (cold)
greeny..i'll hit it up tomorrow..lol...forgot all about it...hahahaha
Old Jan 27, 2009 | 11:11 PM
  #50
gapboi210's Avatar
did you try a stock replacement cap first?
raising the PSi is not good, it can cause system damage. It does however raise the boiling point of the system though.
yeah i replaced it with another stock cap (12 psi i think). same thing....won't not keep air out. replaced it with a 16 psi and now i always have heat.
Oh yeah, what I noticed was with the 2 psi cap if i bled the system and made sure all the coolant levels were good, the next day the overflow would be way over filled and the radiator was low. Seemed like the cap would purge out fluid but not let it back in.
Old Jan 28, 2009 | 06:37 AM
  #51
braxsusriely's Avatar
some snippets if they help
if they help
Old Jan 28, 2009 | 08:37 AM
  #52
maximaman1313's Avatar
safe spot to change radiator/drain fluid? I hear radiator fluid kills cats, and they are attracted to the scent...Im not a cat fan but I hate for animals to die because of human ignorance. My dad has a pea gravel driveway...I was thinking to do it there sine all the fluid will drain through the rocks fast. I really don't want to have a shop do all this work for me since I can do it but am unsure about where to drain the fluid. Thanks again guys.
Old Jan 28, 2009 | 08:48 AM
  #53
BenStoked's Avatar
Jesus was a Zombie.
try to catch everything in a five gallon bucket, and take it to a shop for recyciling. most places will take it for free
Old Jan 28, 2009 | 10:24 AM
  #54
CapedCadaver's Avatar
Call me Wookiee Goldberg
still, try another new stock (13psi) cap. the little metal valve in the middle of the cap is the return valve. make sure it isn't sticking. my heater core started leaking last week on a 13psi cap.. i bet it would have been leaking about a year ago if it'd been on 16psi for an extended period of time.
Old Jan 28, 2009 | 10:30 AM
  #55
PMAX08's Avatar
No the gauge doesnt move around when i stop or drive or get heat and than none, though it doesnt sit right at half either, just before half is where it sits
Old Jan 28, 2009 | 01:00 PM
  #56
for 5 years mine will never go higher than halfway. It always sits just a nudge below half. except when cold and warming up of course. My radiator has a slight crack for 6 months now, and ever since I have had the bubbling sound behind dash when I shut car off. But the temp gauge still operates as it always has. The cooling system on the 3rd gen is pretty damn good IMO. I've drove for 7 hours straight on the freeway. stopped once for gas/**** and an extra stop for another **** break. The temp needle never wanted to go over half. Got 29mpg that trip .
Old Jan 28, 2009 | 01:03 PM
  #57
PMAX08's Avatar
ya i think its good to, just a ***** to bleed, my buddy is gonna put it up on the hoist sometime this week and bleed it on an incline, hopefully that will fix everting
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
