Places to mount amps in the trunk?
Old Feb 20, 2009 | 06:44 AM
cardana24's Avatar
Blown
So I thought this was going to be straight forward. I was going to screw my amps to the back of the rear seat like I have done on my fourth gens. Well the third gen does not have a metal plate behind the seat like my fourth gens. So I have thought about cutting a peice of ply wood and securing it to the open area behind the seat then screwing the amps to that. What have you guys done about this problem? I am mounting one Infinity 4 channel amp, and one JL250 amp, to give you guys an idea on the sizes I am looking at.
Old Feb 20, 2009 | 07:06 AM
Cliff Clavin's Avatar
Way out West
I mounted a piece of carpeted board to the rear corner and screwed my amp on that. It has been there for about 5 years with no issues. I need to get an amp for my sub and I would possibly mount that on the other side, but that would mean moving my jack somewhere.
I also stripped out a bunch of the carpet and plastic stuff, but I didn't mind that.
Here is what mine looks like:
Old Feb 20, 2009 | 08:12 AM
maxitech's Avatar
Mine is mounted to the side of the box.
Old Feb 20, 2009 | 08:46 AM
BenStoked's Avatar
Jesus was a Zombie.
I have boxes for my 6x9's mounted in the stock location in the back. I bought some "L" brackets, and mounted a piece of 1"x10"x(whatever, cant recall the dimensions) wood, mounted my amp there. works fine so far. and its out of the way, for the most part.
Old Feb 20, 2009 | 12:08 PM
internetautomar's Avatar
mod or sell?
I don't have one
Old Feb 20, 2009 | 12:14 PM
cardana24's Avatar
Blown
do you have a picture of that?
Old Feb 20, 2009 | 12:43 PM
Greeny's Avatar
¯\(°_o)/¯
I just stuck mine under the passenger side seat..
Old Feb 20, 2009 | 02:14 PM
Matt93SE's Avatar
STFU n00b!
Make a plate like this... (with or without subs, of course. )
Then just screw them to the back.
Make some rough measurements with tape measure back there, then draw it onto a piece of cardboard. cut the cardboard a bit bigger and then trim until it fits. once you get it fitting right, trace that onto some plywood or MDF and then screw the MDF into the car.
OR... you could build an amp rack like I did...
Old Feb 20, 2009 | 02:29 PM
bigpopaj369's Avatar
if i where u id mount it to the bottom of the rear deck ive mounted several amps there. mines attatched to the back of the seat with some spacers for room for heat to escape. or u could mount it under a seat or completely hide in in the spare tire compartment but usually thers a tire there lol
Old Feb 20, 2009 | 02:56 PM
Pearl93VE's Avatar
I can has?
Mounted mine on top of the sub box itself... don't know if there is some rule where you're not supposed to do that but I've been running it like that for 2+ years with no problems. Little 400w Clarion 2ch amp bridged to a 10" enclosed kicker. Only pic I have is kind of ****ty but here it is:
Old Feb 20, 2009 | 03:54 PM
Matt93SE's Avatar
STFU n00b!
You generally don't want to mount an amp upside down. the amp is designed around heat rising, and uses that to help keep it cool. If you mount it on the bottom of the rear deck, be careful and keep a close eye on it for the first couple weeks to make sure it's not overheating during long playing times. Since it's cold outside right now, be sure to look at it again in the summer when things warm up.
Mounting it on top of a sub box or under the seats is perfectly fine, Given you have proper airflow to the amp. a couple inches of space above it for airflow is fine.
Old Feb 20, 2009 | 10:29 PM
maximagician's Avatar
Does anyone know if mounting amps ON the Box is bad because of the VIBRATION?
Old Feb 20, 2009 | 11:18 PM
Way out West
I think the vibration would be the same or worse in other places around the trunk. The same massive sound waves are punishing everything.
Lots of people mount the amps to their enclosures. One bad thing about that is if someone breaks into your trunk, it is very easy to steal the amp and sub if they can get your box out. I mean, it minimizes the time they would spend getting things.
I have my box bolted to the brace behind the seat, so you have to take out the back seat to remove it.
Old Feb 21, 2009 | 03:19 AM
chunkysause7's Avatar
I custom fit a fiberglass MDF plywood to the frame where the back seats lays up against. I then spaced my amp so i could put some cold cathode lights and so it won't overheat.
Old Feb 21, 2009 | 09:11 AM
Infam0usMax's Avatar
anybody know how to bypass the 6x9 amps?
Old Feb 21, 2009 | 03:15 PM
chrome91's Avatar
ive just got mine sitting in the corner. main reason is when me and another guy did the wiring, we underestimated and the 2 white/blue plugs have like 3" of length from the back seat. its a pain to switch amps
Old Feb 21, 2009 | 03:50 PM
vgkid's Avatar
Cliff Clavin: where did you get that stuff to screw it on?
Old Feb 21, 2009 | 03:57 PM
Kountz430's Avatar
bald aggression est 78
man thats a clean 3rd gen how many watts is every pushing out
Old Feb 21, 2009 | 04:26 PM
505max94se's Avatar
I just recently changed my setup from this...
To this...
I did it to cut down on weight and so I could use my trunk space again.
Old Feb 21, 2009 | 04:36 PM
Greeny's Avatar
¯\(°_o)/¯
Old Feb 21, 2009 | 05:53 PM
mod or sell?
use the thin wires
Old Feb 21, 2009 | 08:23 PM
vgkid's Avatar
wow that is a really nice and creative set up!
Old Feb 22, 2009 | 07:41 AM
Way out West
Hardware store -- True Value to be precise. It cost me maybe $8 or so.
Four matching "L" brackets and two "U" bolts. I just went to the back where they have everything loose and found U bolts that lined up with the holes in the L brackets.
That picture was taken when I first started working on it. It has bent that aluminum bracket some, but it works well (it's been like that for maybe 4 years). It is virtually impossible for someone to figure out how it is mounted when you are in the trunk. When you take the back seat out, it's not that hard to take the box out.
When I go to the track, I take the seats out, anyway, and just unbolt the box at the U bolts and the rest of it comes out without having to take every nut off.
Old Feb 22, 2009 | 11:28 AM
To this...
what the hell...! that is sick... real nice set up but how u gonna hide the wires? or u really dont care about that... it doesnt matter tho anybody that doesnt like tha way that looks is a hater.....! lol but yeah nice set up
Old Feb 22, 2009 | 04:19 PM
vgkid's Avatar
thats not a bad idea. my sub box always slides around under hard take offs or turns. thats not good since i have my wires all under the box
i just mounted my amps to the box, but i know its not a good idea
Old Feb 23, 2009 | 07:16 AM
MaXiMa_RyDaH's Avatar
I mounted mine in the exact same spot
Old Feb 23, 2009 | 09:29 AM
Mostly_Harmless_Mike's Avatar
well...
If I want to re-do my audio I'm going to need to do this because I won't put a loose sub box in my trunk; it gets in the way when I need to put stuff in and would slide around too much because I drive like a *****. How did you go about removing the seats?
Old Feb 23, 2009 | 11:23 AM
Matt93SE's Avatar
STFU n00b!
Seats are incredibly easy to remove. start with reading the stickies and searching if you can't figure it out in 5 min by looking around in your car.
Old Feb 23, 2009 | 10:30 PM
Pearl93VE's Avatar
I can has?
What's all this talk about sub boxes sliding around?... can't you just nail them down with some little L brackets and some short drywall/deck screws?
Old Feb 24, 2009 | 07:10 AM
swowlinc's Avatar
1993 SE
I did mine a little different this time around. I mounted 2 rectangular pieces of some semi rigid plastic I found laying around on either side of my armrest in the trunk. Then I cut it to desired length width and took it out. Next I mounted an amp on each and re-installed. I prefer plastic to MDF for obvious reasons. Plastic is way lighter and easier to cut to fit. Maybe I can find a pic, but its a clean job and when i open my trunk, you cane see the amps at all, just the sub box. I mounted a cap to the sub box so it illuminates through the center armrest.
$0.02
Old Feb 24, 2009 | 07:20 AM
mod or sell?
you do realize the gas tank is under there
Old Jul 20, 2012 | 04:11 AM
dualcoreseb's Avatar
sliding sub. boxes
My 2x kicker L7's use to slide all around in my trunk and one day I got tired of it and used half a can of that spray on bed liner on the cardboard tire cover then placed some rubber shelf liner below the trunk carpet and on top of the carpet then set my box on top of all of that and I haven't had to move it since, even after I whip it around corners
Old Jul 20, 2012 | 12:59 PM
7mJoe's Avatar
I just screwed mine to the floor. You guys have some seriously awesome setups!
Old Jul 20, 2012 | 08:40 PM
maximo018's Avatar
Your not the only one. Simple but not as easy to steal.
Old Jul 21, 2012 | 02:51 PM
7mJoe's Avatar
You got that right!
Old Jul 21, 2012 | 11:21 PM
maximo018's Avatar
You got that right!
Plus I would hate to put all that effort for a nice outcome. Then some a$$hole comes along to screw it up whether they are succesful at stealing my stuff or not. I believe its worse if they don't. All my stuff is here but torn and broken up to where I couldn't use it.
AaronL
Aug 8, 2020 10:31 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
popdedop
Sep 11, 2015 11:17 AM
