odometer
Old Mar 17, 2009 | 04:39 PM
Garf's Avatar
odometer
made a JY trip today and picked up an SE instrument cluster, kind of a bonus since i just wanted a replacement for my instrumment cluster since my odo was dead.
i was wondering how to roll the numbers on the odometer to make them match what my car actually has? i can't seem to figure it out. i'm guessing it's one of those things they purposely make tricky to do/impossible so that ppl don't just roll the numbers back.
new cluster has 380k on it my car only has 210k
thanks in advance guys!
Old Mar 17, 2009 | 06:04 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
just swap odometers.
Old Mar 17, 2009 | 07:56 PM
Gunther's Avatar
His odo is dead, which is why he needed the replacement.
Old Mar 17, 2009 | 08:08 PM
Garf's Avatar
yea what he said,
it's ok i fiddled with it long enough and figured it out. you have to take of the odometer, remove the motor, bend the little hinges that keep the shaft the numbers rotate on and remove the set of numbers, set them, tape them across to hold them in place, then reassemble + remove tape.
more questions:
stock odometer has a top speed of 200 km/h on it (i think thats like 135mph)
and the SE (new one i just installed) has a top speed of 240km/h (like 150 mph)
now my question is will the speedometer read the correct speed i swapped the entire SE cluster, not just the white faces.because the intervals between the numbers is smaller. it feels like it's right on.
oh and it took a couple seconds for the speedometer to start working after the install but now works fine.
just thought i'd share
Old Mar 17, 2009 | 09:04 PM
yea what he said,
more questions:
what was actually wrong with it? broken gears? or a dead motor? you could have just swapped the odometer and swapped its motor to get it working.. no reason to go bending stuff when a screwdriver will do.
Old Mar 17, 2009 | 09:11 PM
Hectic's Avatar
yea what he said,
more questions:
It will read the correct speed I believe, at least it will here in the US. However if you tried to install a MPH unit, it would be be inaccurate unless you used the corresponding speed sensor. I think I tried installing a MPH cluster in a Canadian Maxima I had, either that or I tried installing the Canadian Maxima's cluster in my US Maxima without swapping speed sensors. Whichever it was, it was inaccurate. But if they are both KM/HR clusters and you're using a KM/HR SS, it should be true.
Old Mar 17, 2009 | 09:44 PM
burhan92SE's Avatar
i thought we have both on clusters mph and kph...atleast my max does
other way around....in US mph is on top and in Canada kph is on top but they both still got both...
Old Mar 17, 2009 | 10:57 PM
i dunno.. i think the 145mph gauges are just calibrated to sweep less per-mph than the 125s are...
Old Mar 17, 2009 | 11:33 PM
BenStoked's Avatar
Jesus was a Zombie.
yes. my ve gauges read exactly the same speed as my old vg gauges did (its off by exactly the same speed... gonna get correct sized tires, soon, I hope).
Old Mar 18, 2009 | 12:58 AM
Garf's Avatar
yea i didnt swap from km/h to mph or nething, it's all km/h up here in the great white north. everything including the odometer is working now except for that speedo haha, i'll pop it out tomoro. i'm guessing bad connection/i got hasty and didn't clip it in. was thinking of goin w/ blue 194's but i like the white, blue is too much for me.
Old Mar 18, 2009 | 01:24 AM
if the odometer works but the speedo won't read, then the speedo is bad. cuz the odometer plugs into the back of the speedo, remember? or else maybe you are missing one of the screws for the speedo or something.. but if they are all there then you might want to put the other speedo in.
Old Mar 18, 2009 | 01:03 PM
Garf's Avatar
yea i know that, both speedo's work but as i just found out after i swapped odo motors that i think both odo motors are dead. And somehow the gears jammed on the old odo, but now neither odo motor is working. i'll just go to an electrician and see if they might have a motor that will work if not, another jy trip/ni$$an dealer$hip
Old Mar 18, 2009 | 03:11 PM
LQ91SE's Avatar
IIRC, all you have to do is slide the end of the odo wheel, match mileage, then slide the end back in place. I did this with my 91 SE.
Maxboy23
55
May 1, 2025 06:09 PM
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
Djsmaxima
Sep 14, 2015 11:58 PM
