VE HEADS
Old May 9, 2009 | 05:46 PM
burhan92SE's Avatar
VE HEADS
hi guys...
i am working on my engine and i wanted to get opinions from u guys that before i start putting everything back what should i do or change to the heads to make any improvements...is there any performance cams available for VE? i think i saw Matt mentioning about some performance cams...and how about a lil overlapping? good idea on these engines? i wanna make this engine mechanically strong before i go ahead on other stuff. any opinion is welcome Thanks
Old May 10, 2009 | 05:49 AM
Maxpwer's Avatar
No turbo, no care!
Perhaps if you spent less time making foolish threads and more time searching, you would know there are no cams available for the VE. Seriously......
Old May 10, 2009 | 06:18 AM
Niccos89's Avatar
Not alot you can really do to improve your heads. Use this chance to replace or upgrade sparks and injectors, and replace gaskets (some gaskets can give slightly higher performance than regulars, not really worth the effort and money though).
How often does Burhan92SE post "foolish threads".....Seriously......
Old May 10, 2009 | 08:50 AM
sleepyvg30e's Avatar
did u get a nwp kit yet now's the perfect time to install one?
otherwise u can just get new oem camshafts (if u cant find performance ones or afford custom) there is alot of value to brand new cams on a 100k+ engine
oh yeah and high temp paint on the valve covers
Old May 10, 2009 | 01:52 PM
burhan92SE's Avatar
Perhaps if you spent less time making foolish threads and more time searching......
Old May 10, 2009 | 01:53 PM
burhan92SE's Avatar
thanks niccos and sleepy...
Old May 10, 2009 | 02:35 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well you could get a spare set of stock VE cams and have them base-circle reground. base circle is the circle that would exist if the lobe didn't have any lift at all... if you make THAT smaller, you effectively make the lobe tip more 'prominent' ie more lift (and the machinist can choose where else to grid, which can affect duration too). then you shim it to take up the slack of how much was machined off.
Old May 11, 2009 | 10:17 AM
Jeff92se's Avatar
I'm needing a caw
Is that a big dent in the front VTC assembly?
Old May 11, 2009 | 04:09 PM
burhan92SE's Avatar
no thats just a reflection of something no dents...i got this JDM motor at 55k 2 years ago so my VTCs r pretty brand new but i now have 96k on the motor
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
