Where is all the oil going.
Old May 11, 2009 | 04:41 PM
akurtzer57's Avatar
Well seems like everytime I check the oil about every 1000 miles its damn near dry or 3qt low. Car does not seem to smoke or burn it. The oil does look a little runny when check it. Ive tried cheap oriellys oil valvoline even some good 20-50 and same result. The car is actually my gf 90 se VG Auto. Anyone got any ideas need to take care of this since she likes to forget to check oil and commutes 100 miles a day.
Old May 11, 2009 | 04:48 PM
Greeny's Avatar
¯\(°_o)/¯
See any leaks on or around the underside of the engine?
Old May 11, 2009 | 05:09 PM
biggz2332's Avatar
This is besides the point but isn't 20-50 too thick for these cars
Old May 11, 2009 | 05:34 PM
1991Maxima1991's Avatar
i use 10w 30....
Old May 11, 2009 | 05:49 PM
biggz2332's Avatar
Originally Posted by 1991Maxima1991
i use 10w 30....
Thats what I use too
Old May 11, 2009 | 05:51 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
are you perhaps running rich and washing it down into and dilluting it/thinning it? do you have a wideband to check that with?
Old May 11, 2009 | 05:53 PM
kringle03's Avatar
I second that Emotion
Old May 11, 2009 | 06:04 PM
Greeny's Avatar
¯\(°_o)/¯
This isn't a "what kind of oil i use" thread folks..
Old May 11, 2009 | 06:11 PM
Gunther's Avatar
Would you say the oil looks milky? Could be mixing with coolant, someone else would have to tell you where that is likely to happen.
Old May 11, 2009 | 06:18 PM
akurtzer57's Avatar
should of posted some more info. No visible leaks at all. I normally use 10-30 just gave the 20-50 a shot see if I can make a difference. I have a wideband I could use. She is still getting 24mpg avg so don't belive it is running rich.
Old May 11, 2009 | 06:23 PM
Greeny's Avatar
¯\(°_o)/¯
Well, oil can only go 3 places, leak out through a seal, leak out through the headgasket(into the cooling system), or burning it..since you haven't noticed any leaks, or overheating, my best guess is you are burning it..
Old May 11, 2009 | 06:29 PM
compression still within spec on a warm motor?
Old May 12, 2009 | 11:15 AM
akurtzer57's Avatar
I will do a compression check tonight. First got to get it home. Started a new problem start up car and it dies when put into gear.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
