4th Gen engine in a 3rd Gen. maxima?
Old May 13, 2009 | 02:57 AM
truemax's Avatar
Can you put a 96 maxima engine in a 94 maxima? My 94 is almost at the end of it's journey as far as the motor is concerned. A friend of mine has a wrecked 96 that asked if I wanted the engine. I didn't know if the swap was possible but I didn't think it would considering that they are different generation maxima's. Any help would be appreciated. Truemax
Old May 13, 2009 | 03:45 AM
Niccos89's Avatar
Whats the mileage on your current engine?
Our engines have a fairly long life, unless theyre abused...several 3rd gen owners on this forum have exceeded 400'000+ kms are still running with no drama.
Putting a VQ30DE in a 3rd gen has been done before.
There is even a VQ35DE swap in progress (very close to completion now).
It would be alot of work though.
You'd need the engine, entire driveline, ECU, new speedo, not sure about how engine mounts are done in this conversion.
Old May 13, 2009 | 06:18 AM
DanNY's Avatar
Ad·min·is·tra·tor
sure...with some custom made mounts and some welding skills you should be able to just drop it in.
you need everything from the a pillar forward on the donor car sans body/frame.
Old May 13, 2009 | 06:22 AM
daragez's Avatar
be sure before you swapped it.go with the pro.
Old May 13, 2009 | 06:36 AM
DanNY's Avatar
Ad·min·is·tra·tor
pro what?
Old May 13, 2009 | 07:01 AM
Cliff Clavin's Avatar
Way out West
Unless you have some very good fabrication skills, I would say swapping a VQ into your car is either going to be extremely difficult or extremely expensive (for a shop to do the work).
My suggestion would be to help your friend part out his car and split the profits with him. You should be able to buy a JDM engine that was designed for your car and put that in.
Old May 13, 2009 | 07:58 AM
Niccos89's Avatar
If you're going to track down a "JDM" engine, just find a VE, and add a turbo.
Remember that VEs are DOHC and put out 190bhp, the same as early VQs...the only difference is their weight, but a turbo will fix that little problem, it would be something different and alot easier, with way more support and information available.
Adjust the timing for higher end power, and set the turbo to cover low through mid RPMs - You can't go wrong
Old May 13, 2009 | 08:24 AM
nitrous360's Avatar
Yeah, i think the VQ conversion would be more trouble than it's worth. The VE would be the better option. But if you don't need this to be a daily driver, than go for it. Take the time you need and do it right.
Old May 13, 2009 | 08:37 AM
mmg23max's Avatar
When my VE crap out on me last yr I had a 4th gen parts car that I got my harness, axles, 5 speed tranny,Ecu and crossmember. I just cut the side engine bracket out the 4th with my sawzall and then weld them in my 3rd. I used 3.0 timing for my 3.5 swap instead of the route that aaron92se took.
Old May 13, 2009 | 08:41 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by mmg23max
When my VE crap out on me last yr I had a 4th gen parts car that I got my harness, axles, 5 speed tranny,Ecu and crossmember. I just cut the side engine barcket out the 4th with my sawzall and then weld them in my 3rd. I used 3.0 timing for my 3.5 swap instead of the route that aaron92se took.
cut the engine mount or did you cut out the inner fenders and frame?
Old May 13, 2009 | 08:44 AM
mmg23max's Avatar
the engine bracket that has the 8 point weld to the chassis where the mount goes into and the bolt go through.
Old May 13, 2009 | 08:50 AM
mmg23max's Avatar
pics
This is what it looks like with both brackets installed.
this is front engine side mount bracket.
Tranny side.
Old May 13, 2009 | 08:57 AM
DanNY's Avatar
Ad·min·is·tra·tor
hmmm the pics are not loading for me...anyone else?
edit: saw them on NYCN...looks like a lot of wiring fun. what tranny is in there?
Old May 13, 2009 | 09:03 AM
mmg23max's Avatar
5 speed vq, it's a good amount of wiring invloved but it less than if I would of went the full ECU 3.5 way.
Old May 13, 2009 | 09:12 AM
Jeff92se's Avatar
I'm needing a caw
VQ = aluminum and 15 more ftlbs I believe. As a whole, that's a fairly signficant difference.
Old May 13, 2009 | 09:19 AM
DanNY's Avatar
Ad·min·is·tra·tor
true...aaron got a rat's nest to deal with right now.
Old May 13, 2009 | 09:20 AM
DanNY's Avatar
Ad·min·is·tra·tor
just to add another point to the OP...4th gens are getting to be really cheap. why not just dump the 3rd gen and move to a 4th gen?
Old May 13, 2009 | 09:28 AM
mmg23max's Avatar
lol yep he does. I love my 3rd gen over the 4th and i like the independent suspension plus i love the sleeper look, nobody really expects a 3.5 gen with boost. I like being different also i don't like driving what everyone else drives.
Old May 13, 2009 | 10:29 AM
DanNY's Avatar
Ad·min·is·tra·tor
all good points but it's a lot of work. i don't want anyone to think that they can just swap a VQ in there like it was a piece of cake. there is some additional work that's needed.
if you REALLY love your 3rd gen then do it....but don't think it's a weekend swap.
Old May 13, 2009 | 10:33 AM
Jeff92se's Avatar
I'm needing a caw
with the stillen kit it is.
Old May 13, 2009 | 10:39 AM
James92SE's Avatar
2 VE's are better than one!
Wait... what? I wanna see these pics
*pics of mmg23max's swap I mean
Old May 13, 2009 | 10:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
i thought they discontinued that?
Old May 13, 2009 | 11:19 AM
mmg23max's Avatar
Here is a vid of my brother 3.5 gen(monstorc28).
http://http://www.youtube.com/watch?v=P-kM1NkV5yU
Mine has the the motor out because i'm going turbo and i decided to build the motor before i put it back in the car. When i finish i will put pics up.
this is pics of when we first finish the swap last yr.
http://photos2.hi5.com/0025/729/213/B6otuZ729213-02.jpg
http://photos2.hi5.com/0026/058/409/1kDgX9058409-02.jpg
http://photos1.hi5.com/0024/510/972/8aNdRO510972-02.jpg
http://photos2.hi5.com/0024/921/901/ZTjT7n921901-02.jpg
http://photos4.hi5.com/0026/859/927/JBcPJG859927-02.jpg
http://photos4.hi5.com/0026/991/063/2c.DwU991063-02.jpg
Old May 13, 2009 | 11:23 AM
mmg23max's Avatar
yea that's true it's not a piece of cake but as we see it can be done. When aaron92se motor took a crap at 1st he didnt want to do the swap, but then I told go for it you won't regret it and now he went through with it and it's a beautiful feeling when your project comes to life.
Old May 13, 2009 | 02:26 PM
internetautomar's Avatar
mod or sell?
in my area I've had more luck finding a cheap 4th gen than a cheap (non-VG) 3rd gen.
Old May 13, 2009 | 04:53 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well the VQ30DE has 15 more lb/ft of torque than the VE, and using the VQ30DE-K intake manifold boosts that to 220HP and more torque as well.
for anyone wondering, aaron HAS driven his 3.5gen, and just has to wire up the TPS so his transmission will shift properly (automatic) and then he's done. he's got debuloz cams, headwork, HR valve springs and head gaskets, full ECU swap, and is still using his original VE VLSD automatic transmission (after i suggested to him that the 04a and 04v might have the same bellhousing-to-tranny-case bolt pattern) with a 4th gen bellhousing.
Old May 13, 2009 | 05:06 PM
Greeny's Avatar
¯\(°_o)/¯
Another +1
4th gen and even 5th gens are getting super cheap around here now, as dan said, unless you are madly i love with your 3rd gen , i personally see no point in going through all the trouble swapping a VQ series engine..
Some examples..
http://nashville.craigslist.org/ctd/1157669523.html
http://nashville.craigslist.org/cto/1168454848.html
http://nashville.craigslist.org/cto/1157517817.html
http://nashville.craigslist.org/cto/1157110976.html
http://nashville.craigslist.org/cto/1134314420.html
Old May 13, 2009 | 05:14 PM
biggz2332's Avatar
Yea they basically have the same engine, and like every1 is sense 4th gen value is dropping so if u really want 2 do that just get a 4th gen..... IMO I would rather the 3rd gen because the 4th is driven by everyone
Old May 13, 2009 | 07:33 PM
sleepyvg30e's Avatar
dont bother swapping a vq30 in their the engine its not really better than a VE the VQ 30 gets a lil more torque but the VE is proven to get higher top speed than a VQ
i would love a 3.5 swap especially if u can fit a 7th gen vq 3.5 that makes 290hp but obviosly that engines gonna be a lil pricey till the jdm's start showing up
VE
190 hp @5600 rpm
190 ft-lbs @4000 rpm
VQ30
190 hp @5600 rpm
205 ft-lbs @4000 rpm
VQ35 (2002 model)
255 hp @5800 rpm
246 ft-lbs. @4400 rpm
VQ35 (2009 model)
290 hp @6400 rpm
261 ft-lbs. @4400 rpm
this is what nealoc187 had to say in an old thread:
3rd Gens still get love.
With Nissan's Gen1 NVCS system in place (assuming the VTCs are still working ) and the variable intake manifold on the manuals, the old VE motor has better top-end than the popular 4th gen VQ30DE. The gearing is the same between all of the 3.0's, and the VE can hold the torque curve flat enough that you can pretty much shift at or close to redline in all gears with perhaps only very slight short shifting needed.
Note the optimal 3-4 shift point for the VE at 95 mph vs the 4g VQ at 89 mph. This means that the VE will be able to hold 3rd through the 1/4 mile whereas the VQ will either be wheezing at the top of 3rd struggling to finish, or having to get shifted to 4th which costs time. Overall due to more torque and lighter weight, the VQ is a tad quicker, but the VE is no slouch and will give a VQ a good run from a roll. Note also the higher calculated top speed of the VE in the low-140 range vs the high-130 range of the VQ. VE power!
Old May 13, 2009 | 08:12 PM
Maximan190's Avatar
the 3rd gens age is its major killer at this point... as im in the beginning stages of a JDM VE swap, im realizing all over again certain things that make me want a new-ish-er car... wear/tear, rust, battle scars, etc
But if i were to replace it and get something new(er) im going to be a picky bastard and want what i want and thus it will be quite pricey. So for now i stick with my 3rd gen and keep up on it since id rather have this than any new car today in its class
if you do swap to VQ id go whole hog and do the VQ35 or else stay with a VE if you dont want to invest a ton of time/money
Old May 13, 2009 | 08:42 PM
Aaron92SE's Avatar
NWP Engineering.com
I just got it running on Monday for the first time!
I put 30 miles on it today driving it around. I am trying to get more videos though for everybody.
But yeah, the amount of wires and schematics that you have to deal with is a lot. It takes a LOT of research and patience. I now know the 02 Maxima FSM pretty well. But I'm happy to say that the engine is in and running. I hope to have my exhaust completely tomorrow so I can drive in peace instead of with open headers.
Old May 14, 2009 | 06:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
i know i saw your thread. good to hear you have it running.
think you can cram more crap in your sig since it's really just not big enough.
Old May 14, 2009 | 09:05 AM
Jeff92se's Avatar
I'm needing a caw
LOL at Dan.
Congrats Aaron! Man you did alot of work! Pretty fast too.
Old May 14, 2009 | 09:20 AM
Aaron92SE's Avatar
NWP Engineering.com
Thanks guys.
I worked every single waking moment on this engine to have it done well before MAXUS 09. I still need to tune this thing. Only 43 days to MAXUS! I gotta hurry if I want it to be a contender in the Drag Showdown event!
Old May 14, 2009 | 12:21 PM
mod or sell?
Originally Posted by Greeny
Another +1
Some examples..
we've got 5th gens going for less than $4k around here already.
I bought my last 4th gen for $260 (sold it sans radio for 340)
last years 4th gen was $700
this years I30t was $1650
I have NO luck finding a drivable VE for less than $1500. A driveable VQ under $1500? no real problem. I am waiting for a guy to get back to me on a 96 for $500
Old May 14, 2009 | 03:19 PM
chrome91's Avatar
gotta agree, im bumpin 405k with absolutely no major repairs ever done. these cars can last to 600k-800k or possibly 999k as long as theres no abuse. the people who complain on ebay that these cars have crap engines are the ones who rev at 6k for no reason and do neutral drops
Finkle
Sep 27, 2015 09:53 PM
wyobbagy
Aug 15, 2015 02:28 PM
MaxStock
Aug 12, 2015 08:33 AM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
