battery isn't charging - help
Old May 20, 2009 | 08:01 AM
jruss1601's Avatar
I've changed the DOHC motor from one maxima to the next and just got it up and running. I bought a new battery for the car and after a few weeks of very infrequent use, the battery dies. I take the car up to autozone and they say the battery is not a getting a charge, but doesn't say what the problem is. So i take out the alternator and get that checked at a separate garage. They say the alternator is fine. What other options do i have?
Old May 20, 2009 | 08:51 AM
Niccos89's Avatar
Jump start/Roll start it, and take it for a 2 hour cruise.
No success = empty the battery, refill it, and retry.
Old May 20, 2009 | 09:25 AM
maximaman1313's Avatar
checked all wires for loose or corroded connections.
when autozone tested battery they should of been able to tell if the alternator was putting out a proper charge or not.
get it running, jump starting or however. and check the voltage of the battery while at idle
Old May 20, 2009 | 01:18 PM
Cliff Clavin's Avatar
Way out West
Most battery shops will test your entire system (battery and alternator) at the same time.
You might want to clean the battery terminals and connections really good and make sure everything is tight and clean with good contacts.
Like 1313 said above, I would check all the wires for corrosion or loose connections.
Old May 20, 2009 | 02:09 PM
internetautomar's Avatar
mod or sell?
there are an assortment of things that can cause issues.
Heck the other day we found out the main relay was causing charging issues on my dad's corolla.
Old May 20, 2009 | 05:21 PM
sleepyvg30e's Avatar
+1 most likely a damaged wire but try cleaning off the battery terminals especially if u see any of that blue crap on em
how did you end up figuring out what the problem was?
Old May 21, 2009 | 05:24 AM
jruss1601's Avatar
Well, theres no need to roll or jump start the car. We just recharge the battery and start it up. Problem is that it dies so fast. As for the battery terminals - those are clean. I replaced them both a few months ago. The wires are probably the problem.
Autozone wouldn't say whether it was the alternator or not, even when i asked them. They just said the battery wasn't getting a charge
Old May 21, 2009 | 06:33 AM
mod or sell?
a very hot relay and a couple hours of diagnostic time while trying to figure out the wiring diagram.
Old May 25, 2009 | 10:07 AM
Garf's Avatar
check grounds. Get alternator tested. that's what a guy would do.
jmlee44
Oct 2, 2022 02:13 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
bigfrank
Oct 1, 2015 12:51 PM
