Temp/Perm Fix for Failed Regulator
Old Jun 1, 2009 | 07:34 PM
fotoman's Avatar
Ok hope this helps those who want a temp fix for a failed regulator to hold windows up in place. The wire hangar holds the window up in place from the bottom of the window.
Hopefully your screws inside the doors are not rusted thru - WD40 or rust penetrate might be needed.
Most of you will never suffer the misery of a failed regulator .. thanks to BenStoked this is how I fixed mine temporarily.
I remembered to take pictures as some of us have never saw the inside of your doors.
Materials - one wire drycleaner hangar cut in half for each window.
Screwdriver and masking tape to hold window in place. ALSO if your screw are rusted see above...
I can only have 5 images so I picked them carefully
Once you get the door and panel off here is a pic of the wire hangar as I followed BenStoked's directions ......
ANYWHY here is the prototype of BenStoke's famous wire window crutch.
Use masking tape to hold the window glass up.
You make 2 of these for each end of the window .. you have to adjust the bend of the wire according each individual door or window opening. You start with the bend to put to hold the window up from the bottom and you bend the other sections as you go along.
You can remove the masking tape to see if the window drops any or stays close and adjust your bending of the wire hangar as necessary.
NOW WHAT I DID was i put the panel back over the overhanging wire ... so you couldnt see the wire hanging down ..as i think it will hold the wire in place better.
KINDA OFF TARGET A LITTLE BIT
I had wanted to remove my regulator to see it up close and It was bugging me as my window would only go down 1/4 th of the way and i wanted to know why ....
While trying to look down inside the door (DIFFICULT) I noticed a reflection of the top part of the regulator and i could see that the top tube had broke under the bottom and the wire had no tube to go thru ...
HOW would I get the regulator out? By cutting the wire at the bottom????
Put the panel back on the door
Here is the finished project - Hope This Helps as a Temp or Permanant Fix for Your failed regulators.
Old Jun 1, 2009 | 08:11 PM
BenStoked's Avatar
Jesus was a Zombie.
Thank you, thank you.
better writeup than mine, but w/e.
got pics?
edit: and there's no "R" in my SN, nub!
edit2: nm about the pics. my computer is being gay, and not loading them
edit3: nm about my computer being gay, its geocities that's being gay.
upload 'em to photobucket, or tinypic, or something.
Old Jun 1, 2009 | 09:28 PM
James92SE's Avatar
2 VE's are better than one!
No you don't have to cut the regulator.. You have to free the glass from the regulator and when you take all the bolts out that hold it in, you can snake it out of the opening/space at the bottom.
Old Jun 2, 2009 | 12:29 AM
fotoman's Avatar
The window comes down only so far so I cant get to the screws/bolts that hold the glass onto the regulator, I THINK the wire has twisted and gotten caught on something .. it feels like the left side tubes with the black covering are ok ... if the silver wire or cable is supposed to only run down the middle of the rail it is off track as the wire was over where the line is drawn in the white in the picture above.....
Why does it click when I press the window switch instead of hearing the motor running, does that mean the motors stuck??
Old Jun 2, 2009 | 12:33 AM
fotoman's Avatar
got pics?
I had a bigger writeup but i was only limited to 5 images so I make this brief report with photos .. I need to create a photo bucket account and your name has been edited.....I KNOW REALIZE I couldnt did it in 3 parts!!!! I might do a re-write later .....
I would love to do my other 2 doors temporarily but I have a screw stuck in the same place on both doors!!!
Its the screw on the left thats holding the bottom of the long handle on both drivers and front passengers doors
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
