Power lock will not go up
Old Nov 24, 2001 | 08:20 PM
JoeWillie
The power lock on the front passenger door will not go up when the switch is hit. It will go down. All the other door lock work fine. I thnik it is the actuator. I'm not sure. I looks like it hard to get at. I welcome all input.
JoeWillie
Old Mar 15, 2002 | 12:37 PM
wyskibumm's Avatar
I had the same problem wiht my front passenger door lock. The lock wouldn't pop up with the rest of the locks, so i went on ebay and for 7 bucks got a 2 wire actuator. I mounted it to my door then plugged its green wire to my existing brown/white striped wire. And i hooked up my solid brown wire to its blue wire. It works great now! Note: the brown wires i was talking about are wrapped up in black tape with two other wires (4total) and then plugged into the existing actuator, so you have to expose them and cut them off of the connector, but then replug the other 2 wires back into the broken actuator (dont ask me why though). If you have any questions e-mail me jlunde944@hotmail.com
good luck
Old Mar 17, 2002 | 10:17 PM
JoeWillie
Thanks for the response. When I first looked into the problem I could not see the actuator. I had the door panel off. So i kind of put it on hold.
Where exactly is the actuator location in the door(passenger side)? I can pick up the part at the dealer.
Thanks a lot,
JoeWillie
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
