92 maxima SE white smoke coming out exhaust
Old Jun 16, 2009 | 03:05 PM
92maxima92's Avatar
Hey guys I just replaced my front 3 injectors and It ran fine the first five mins to work then when i left work it was shoothing white smoke out my back end of my exhaust. When i reved it before leaving when i noticed it was smoking my rpms dropped to almost 0 and it almost stalled. So when i got home i unplugged the front three coils one by one and the middle one didnt do anything. So i swapped it with another one to make sure the coil wasnt bad and it worked fine. Is one of my injectors i just bought stuck open and shooting alot of gas into my car making the smoke??? The three injectors were bought off of rockauto.com and they are remanufactured.
No smoke was coming out of the exhaust before i replaced the injectors!!
Old Jun 16, 2009 | 03:15 PM
Greeny's Avatar
¯\(°_o)/¯
Do not buy remans, they are mostly junk..new only..
did you replace the injector o'rings with new oem(nissan) o'rings??
Old Jun 16, 2009 | 03:26 PM
92maxima92's Avatar
no but could that cause alot of white smoke?? Should i just buy new orings and put them in before i get new injectors?? and it didt appear to be working because when i unplugged the coil it didnt have a rpm drop.
Old Jun 16, 2009 | 03:32 PM
Greeny's Avatar
¯\(°_o)/¯
Yup, re-using the old o'rings usually will cause fuel to leak past them into the cylinders= you running hella rich. Definitely put new oem (genuine nissan) o'rings on all the the injectors you replaced.
Old Jun 16, 2009 | 03:36 PM
92maxima92's Avatar
yeah its running really rich. I had two of my buddies stop by that are machnics and i had it running for like 20 min and it burned a quater tank in that time. i guess im off to get orings and rip it apart again. Thats again greeny yours always on top of ****!! Ill let you know if that works.
Old Jun 16, 2009 | 09:47 PM
Hectic's Avatar
By far the most important thing to do is lube the o-rings with petroleum jelly and seat them very carefully by screwing the hold down cap as evenly as possible. New o-rings isn't the magical cure, they will pinch just as easily as used ones when installing these terribly designed injectors.
Old Jun 17, 2009 | 05:18 PM
92maxima92's Avatar
All new orings came on the injectors except the one that is between the fuel rail and the engine. Thats the one that i didnt replace. Does anybody know if you can buy them by itslef instead of a oring injector kit??
Old Jun 17, 2009 | 05:24 PM
Greeny's Avatar
¯\(°_o)/¯
Buy them from your local dealership..
FYI: the 4th gen(VQ30DE) injectors and o'rings are the same part as the VE30DE. this may help you locate them faster..
Old Jun 17, 2009 | 05:27 PM
92maxima92's Avatar
Theres not a close dealership im trying to order them online. anybody know what the oring is called??
Old Jun 17, 2009 | 05:34 PM
Greeny's Avatar
¯\(°_o)/¯
http://www.courtesyparts.com/16412f-...4-p-43555.html
http://www.courtesyparts.com/16412fa...4-p-43557.html
order both..
Old Jun 17, 2009 | 05:38 PM
92maxima92's Avatar
It doesnt look like either of those. Its thicker and looks like http://www.rockauto.com/catalog/raframecatalog.php the beck arnley the one on the left
Old Jun 17, 2009 | 05:44 PM
Greeny's Avatar
¯\(°_o)/¯
from the left...Injector rail insulator(under the fuel rail)/ looks to be the pintle cap maybe, not sure/ Large top injector o'ring/ small bottom injector o'ring
Doesn't matter though, get the genuine nissan o'rings in the links i gave you. the aftermarket o'rings tend to suck..
Old Jun 17, 2009 | 05:49 PM
92maxima92's Avatar
Its the injector rail insulator all the other orings came on the injectors. the links you posted dont look like it (the one all the way on the left) are they gonna work for the one i need to replace??
Old Jun 17, 2009 | 05:58 PM
Greeny's Avatar
¯\(°_o)/¯
oh ok, so you need the insulators on the bottom of the fuel rail??(these sit in between the fuel rail and the lower intake plenum) right??
this--> http://www.courtesyparts.com/16603fa...4-p-43613.html
while you're at it, bookmark this link..
http://www.courtesyparts.com/maxima-...1610_1611.html
Old Jun 17, 2009 | 06:01 PM
92maxima92's Avatar
Thats exactly what I didnt replace. Can this cause my car to smoke like that and by the way the smoke smells like straight gas.
Old Jun 17, 2009 | 06:07 PM
Greeny's Avatar
¯\(°_o)/¯
nope, the insulators have nothing to do with the rich running condition..you either have a bad injector(good chance since you bought crapa$$ remans), or a pinched o'ring on one or more or the injectors you replaced..
Old Jun 17, 2009 | 06:10 PM
92maxima92's Avatar
ok my buddy thought i got a crap injector stuck open. When i unplugged the front middle ignition coil the engine didnt lose any power?? So i guess that injector is bad or is not sitting right.
Old Jun 19, 2009 | 01:24 PM
92maxima92's Avatar
OK so I took my fuel rail out again and took out my middle injector (the one that was bad?) but anyway I guess i didnt install it properly and the orings pinched and got cut so Im leaving now to get new ones and then install them right away ill let you guys know what happens. Thanks for the help and greeny im going to the nissan dealer instead of getting crap parts LMAO!
Old Jun 25, 2009 | 02:25 PM
92maxima92's Avatar
anyboy know What is the cap called that screws down on top of the injector??
Old Jun 25, 2009 | 02:41 PM
92maxima92's Avatar
And does it matter what color the injector is?? the guy at the maxima dealer said there is blue and black and my injectors are red??
Old Jun 26, 2009 | 05:48 PM
internetautomar's Avatar
mod or sell?
you have a DOHC 24 valve motor?
blue and black are for the SOHC 12 valve motor
Old Jun 28, 2009 | 08:34 PM
CMax03's Avatar
That's not true! I've got a VG30E and they're tan...Those guys in the dealer don't know there *** from a hole in the ground as far as I'm concerned, they've been wrong too many times with questions I've asked ...
Old Jun 29, 2009 | 11:56 AM
mod or sell?
you have pink tops with blue or black dots.
93-94 have pink tops with green or yellow dots.
DOHC got red tops, nodots
maxinout93
Oct 27, 2015 01:29 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
BassAddictJ
Aug 4, 2015 11:38 AM
