Aftermaarket Radio Stopped working?
Old Jul 9, 2009 | 06:45 AM
-ReLLiK-'s Avatar
I have an aftermarket radio in my car. It was in there when i purchased the vehicle. One day I plugged my TomTom GPS in the cig. lighter and while driving all of a sudden my radio cut off. Next day, I start the car and radio comes back on fine. I plug the TomTom back in for more use the day after that and radio cuts off and hasnt came back on since.
Ive checked fuses and they're all good and ive even checked the flaceplate to see if its making good contact and it is. Does this mean my damn radio has blown due to this damn TomTom??????
Old Jul 9, 2009 | 07:46 AM
nitrous360's Avatar
Remove the head unit and make sure it's wired properly. Sounds like it's not.
Old Jul 9, 2009 | 08:18 AM
Niccos89's Avatar
Head unit was wired off the cig. lighter wire, most likely.
Run a new dedicated wire for the head unit
Did you remember to check the back of the head unit?
Old Jul 9, 2009 | 04:21 PM
internetautomar's Avatar
mod or sell?
step 1, remove radio and check to see if an adapter harness was used.
step 2, good luck
Old Jul 9, 2009 | 09:38 PM
DennisMik's Avatar
step 2, good luck
are you talking about life in general or working on his car?
Old Jul 11, 2009 | 03:43 PM
-ReLLiK-'s Avatar
took it to the car audio store (thursday). Whoever the previous owner was ran the ground to the antenna (wtf?). They ran a new ground and crimped all the other wires, but shortly after driving home, it cut back off...
Today (saturday) on my way back homw from work it was working fine so theres a short somewhere. Monday theyre going to look at it again...
Old Jul 12, 2009 | 07:13 AM
mod or sell?
um that is totally common /normal. from the factory our cars don't have a ground wire connected in the harness. It grounds through the antenna. I have done it with many aftermarket units too.
Old Jul 12, 2009 | 10:11 AM
nitrous360's Avatar
When I install head units I always hook up a new ground. Sometimes when you use the factory ground you can pick up static, distortion, even engine whine. Also, I always solder connections. I don't trust crimped connections.
Old Jul 12, 2009 | 01:46 PM
-ReLLiK-'s Avatar
Oh ok see i never knew that. I suck when it comes to the electrical part of a car.
Yeah they ran a new ground. From yesterday until right b4 i made it home today my radio as working fine. Then i hit a fairly rough bump and it cut back off
Old Jul 13, 2009 | 01:34 AM
Niccos89's Avatar
Don't give them any more of your money, find someone who'll do a proper job, first time, no hassles.
Old Jul 13, 2009 | 10:01 PM
burhan92SE's Avatar
try another head unit...its either has bad ground connection or bad it self...where/how did they run the new ground connection to/from?
Old Jul 14, 2009 | 06:33 AM
-ReLLiK-'s Avatar
OK they say the problem was that the socket that holds the fuse in the back of the radio was allowing the fuse to shift, so everytime they would jiggle the fuse, the radio would cut on/off. They replaced the socket and so far my radio has worked fine. Ill update if it cuts off again (knock on wood)
jerrod99_se-l
Aug 27, 2015 08:27 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
MikesChevelle
Aug 9, 2015 11:50 AM
kenc15
Aug 5, 2015 08:29 AM
