Bad Injector or Bad Coil Pack?
Old Aug 7, 2009 | 10:56 AM
hoyshnin's Avatar
Baby's on the Half Tip!
My VE is running rough and I have a code 51, so it looks like I have a bad injector. I tested the 3 accessible without taking the intake manifold off (there's no way to test injectors 1, 3, and 5 without taking off the intake manifold, is there?) and my number 4 injector measures infinite resistence (my multimeter just stays at a "1"). I thought I remembered reading somewhere that a reading of "1" on the injector could mean that you have a bad coil pack, is that true? It doesn't really make sense to me but I thought I remembered hearing something like that somewhere
Also, is it possible to replace the #4 injector by just unscrewing the 2 screws on the cap and pulling it out, or would I need to take off the intake manifold and everything?
Thanks!
Old Aug 7, 2009 | 10:05 PM
hoyshnin's Avatar
Thanks!
Nevermind, I figured it out. Turns out that it was definetly a bad injector. I replaced it with a bosch injector (oem). It was pretty easy overall, although I needed to remove the fuel rail to get the injector out by placing a screwdriver on the tip of the injector and popping it out with a hammer. If one of my rear injectors fails, I'll replace all three of those at once, but right now I just don't have the time or funds.
Old Aug 7, 2009 | 10:25 PM
James92SE's Avatar
2 VE's are better than one!
Good deal it was on the front bank. I have a bad injector on my rear bank on my "new" VE
Old Aug 7, 2009 | 11:21 PM
burhan92SE's Avatar
Thanks!
Yes There Is.
Old Aug 8, 2009 | 11:55 AM
Max_5gen's Avatar
Thanks!
Injector resistance is unrelated to the state of a coil pack. I hope this helps restoring of your common sense .
PH98I30
20
Mar 25, 2020 03:44 PM
gustavison
Oct 4, 2015 06:50 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
