Timing Belt Kit??
Timing Belt Kit??
I was looking at this timing belt kit for my 93 vg30e. The company or manufacturer is called GATES. It is a complete kit with the belt and the tensioner, and it is the cheapest that Ive seen so far at only $44.64 Was wondering if its a good buy?? Its on amazon.com.
well, heres a thought for you, does it say if its for the round tooth or square tooth? you have to keep in mind that our VG's have 2 different types. one will be round tooth and the other will be square tooth so if you order it from amazon.com and it didn't specify for which one it is then you are out $45 my friendl. i suggest that if you decide to keep the car go to your Nissan dealer and buy the OEM belt and take your VIN as that will tell them which belt you will need unless the engine was changed then the only other way is by taking off the timing belt cover and you will see which belt it is, either square tooth or round tooth. point is just buy OEM parts when it comes to timing components. here is the list of parts from Nissan that i bought:
2 cam seals
1 crank seal
timing belt
timing belt tensioner
timing belt tensioner spring
timing belt tensioner stud
timing belt tensioner lock washer
timing belt tensioner washer
timing belt tensioner nut
timing belt tensioner spring stud
water pump
thermostat
paid nearly $250 for all the parts from Nissan.
2 cam seals
1 crank seal
timing belt
water pump
thermostat
if your car has the ORIGINAL engine, then all 89-92 are square, all 94 are round, and apparently 93 can be either, depending how late into the 93-model-year production run your car was built.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
