is my trans slipping?
Ive had my 92 GXE on power mode for a while. If i hit the brakes and slow down, then hit the gas again (like braking for a turning car ahead), sometimes it will "pull", like a gear change when you go up a steep hill. Also, today after i stopped my foot slipped and i punched the gas a bit hard, there was a small delay then the car went, with the "over a bump" feeling
Ive never done anything overly aggressive on the car and no hard accelerations/neutral drops, but then again its got over 400km on it. Are both of these symptoms of a slipping transmission or just because its in power mode? These things never happened when it was in normal mode, and the "over a bump" delay has happened maybe 2-3 times ever, and its because i accidentally hit the gas suddenly hard
interesting. Like i said, the lag has always been when my foot slips or gets antsy and i punch the gas too hard. otherwise, it shifts like new.
Anything i should do/worry about unless it gets worse? The pull has been happening for pretty much a year now and its never become more frequent/worse, it often happens when ive got someone in a Civic ahead of me doing a semi turn and a Skyline up my **** going 80 and i have to giv'er a bit to speed up again
Also you might want to check your trans fluid for color and maybe smell (some say that you can smell 'burnt' fluid
i'll give that a smell tomorrow
i of course googled before i posted, and there was someone else with a different car doing the same thing and high mileage. One person said to do a trans fluid flush and a few other people said on high mileage cars, a flush will just make things worse
is that BS or should i get my trans fluid flushed?
Good to know, i wont flush her then.
Anyways, i'm selling my aquariums and that cash along with some spare money will be kept incase i eventually need a rebuild. I promised myself i wouldnt give up on this car until everything failed so i guess its time to keep my word
drain and refills works for me.
i do the drain and refill 3x's.
drain and refill then drive for about 30minutes or so. and i repeat.
i had a friend of mine test drive my car becuase my 1st-2nd shift was iffy.
he tells me to start looking for a new tranny.
but the thing is...it's been doing it for about a year and 1/2.
the vg tranny is only a ticking time bomb if you don't change the fluids like you should.
oh yea and get and external tranny cooler...it
helps.
helps.
*DIDNT WANNA MAKE A NEW THREAD* GOT MORE PROBLEMS... I found out that my trans had 2qts over the limit took out the two now 1st gear doesnt pull like it use to... does this mean my tranny is pretty much done for?
Are you measuring the tranny fluid level when the engine is hot and running . the dip stick should be hot to the touch. You should also shift through all the gears before checking.
Even if the fluid was really off, I would try a drain and fill anyways.
damn... lol yeah that price range is sick but im guessing it just my first gear that is off and im thinking about buying another GXE but its green. thanks for the help and i will check the level again today.
When my transmission went out, I got a "reconditioned" transmission for about $750 and a 6month guarantee. Yeah! 6months!!!
I had it installed by a shop for about $650.
So altogether I spent $1400 for a transmission...
From what I understood, reconditioned means that they merely cleaned the transmission and did some really super minor inspection/testing, if any at all. Basically, the company I got the trasmission from (ATTARCO), and they get their transmissions from Japan.
The explantion I got from one of their service guys was:
Japan's emissions regulations are way more strict than here in U.S. So, when the Maxima is decomissioned based on emissions, we buy their parts and re-sell them here.
Now, I don't know how much of what the service guy said is true, but, I thought I was getting out of an expensive bill by getting a used transmission.
Of course, ATTARCO is in CA so the shipping is what will hurt ya. But, something to consider (ie. looking into used-transmissions).
Good luck!
Well... guys I got another question I took her out for a ride yesterday and i know for a fact that im loosing power from my studs being gone i think two of them are gone where can i get some to replace them? can i just get some hex bolts? but back to the TRANNY SUBJECT when ur tranny fluid heats up isnt it suppose to be at the hot mark on the dip stick? i checked it yesterday when i stopped it hits all the gears but it just doesnt pull much in first. could this be because its not enough tranny fluid?
I had two guys tell me to replace the strainer? i dont know what that is...
dont know, but I experienced a similar problem. I noticed one day that my transmission started to slip a little, then it seemed like the car was loosing power and stuff, I would floor it, and it would not take off like it used to do! Then there was this straining noise coming from the transmission. I checked the fluid level and it was turning a little darker than normal. It eventually went out with little to no warning almost leaving me stranded in the middle of nowhere on a cold night about 30 miles from home. Its a good idea to change the fluid regularly as I neglected to do to mine for 50,000 miles. I will be replacing the transmission in my car as it has been very reliable for the 50,000 miles of my ownership even with 225,000 miles still a great car! After I get the tranny installed, I will install an external transmission cooler to help prolong the life of it.
Just got mine back from being rebuilt/overhauled.
The total was $1808.37
He showed me all the burnt parts.
The shop said it wasnt in bad shape for 341k miles.
He even gave me a 50k warranty.
The shift points seem to be really pronounced now.
I hope this lasts for a long time
I experienced a somewhat similar problem. My trans is not shifting from 1 to 2 unless i let off the pedal a bit, I did a lot of reading. even tested the tps witch was at 1.5 closed and went to open when throddleing. I replaced it and adjusted it and still have the same issue. its a 1992 auto se 6cyl 103K miles. Looks like I may need to get another tranny, Any Ideas???
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
carlosvq30
Sep 26, 2015 09:44 AM
