doin a VE to VG swap! this is backwards now!
i know i know it's been talked over doing the VG to VE swap, but i'm so fed up with trying to do custom turbo stuff to the VE, i'm to the point where i may buy a VG from the junkyard and start building it to go into my VE. OK, I believe it was maxima mike that said that the VE and VG's had the same tranny housing (sorry maximamike if it wasn't you) i have heard they will, and they won't bolt up. either way, i can get a good mileage engine from a junkyard, but it's got an auto tranny attached to it. the manual tranny there for a VG is pretty high in mileage and i woudlnt' really trust it. anyway, ideas on the tranny would be appreciated. I am going to boost my 3rd gen, there's no doubt, but right now i'm planning you know, and i think it may actually be more cost effective, and better from a performance standpoint. has anyone ever done this or am i a crazy crack smoking fool? any help would be appreciated, and i know you're all sick of this topic, but this is reverse so maybe it's a little different. my buddy did the turbo upgrade on his Z so i could aquire his turbos. . . . like i said, right now i'm in the planning stage. also, would anyone be interested in my VE. VTC's have been replaced. . .thanks, lata
Re: doin a VE to VG swap! this is backwards now!
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
VG-T stock output is about what? 200hp or less? Stock VE is 190hp. Simple turbo VE output is estimated at another 40-50hp at only 5.5psi w/ no add-ons. Tune it and who knows? SC 4-gens get close to 270hp at the flywheel w/ only FPR.
If you really want a VG maxima, you could probably just sell and buy. You would also probably come out ahead in the deal.
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
Originally posted by Maximum5spd
Yes you right almost same hp, but things you can do to a VGT....
So same bottom end but dohc heads, Varible cam timing, and coil on plug ignition.
You can do w/ a VET. hehe. Same basic bottom end(iron block) JWT offers an ecu for the VE so I would "assume" they could program the ecu for boost like they can for the VG ecu. I do believe bigger injectors are available for the VE also(although I don't know which)
*VE 5-speed power!*
Jeff's right.. You can get more power out of a VE-T when tuned right. But the VE-T hasn't been successfully done (besides CZAR and maybe some unknown people). The VG-T has been done by quite a few people. Plus with the VG-T (assuming your swapping VG30ET), your compression is lower so you wouldn't have as much problems with detonation (assuming your running 6psi or so) as you would with a higher compression engine such as the VE.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
