rpm dead
Old Sep 9, 2009 | 11:38 AM
nismo_vq's Avatar
Shift
rpm dead
anyone have an idea as to why my rpm doesnt idel anymore?...
im thinkin its the wirings but could it be the cluster?
Old Sep 9, 2009 | 11:40 AM
biggz2332's Avatar
do your other gauges function properly
Old Sep 14, 2009 | 09:03 AM
nismo_vq's Avatar
Shift
yes all the other gauges are working fine.. jux the rpm
Old Sep 14, 2009 | 10:45 AM
chrome91's Avatar
like the needle on your cluster is not working? mine isnt either, it will work maybe 5% of the time then it will flip around wildly, but mostly it just stays at the bottom.
i think its wiring, because when mine works (again rare and usually for 10 seconds before it limps or thrashes) the wires must get good contact then i hit a bump and they lose it
Old Sep 15, 2009 | 10:38 PM
burhan92SE's Avatar
try to replace the whole cluster with junkyard one and see if it works...if it doesn't then u have problem and u will have to print out the wiring diagram from the fsm and locate the wire and fix it....i knew wat color wire was it but i cant remember now...
edit: its LG/B and B wire for tacho meter...pull out the cluster and inspect it for any lose connection..
Old Sep 16, 2009 | 12:33 PM
biggz2332's Avatar
yea do what he says, then come back with your results
Old Sep 22, 2009 | 10:34 AM
nismo_vq's Avatar
Shift
yea thanks guys... ill get back
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
markevans999
Sep 10, 2015 04:29 PM
