good deal?
Old Sep 15, 2009 | 02:06 PM
  #41
burhan92SE's Avatar
ok so only when you are moving... hmm... are you sure it's got to do with the tranny? as in, could it possibly be brakes or wheel bearings instead?
i jus came bak after test driving it....noise comes doesn't matter if the car is running or idling...if i let the clutch go while idling noise comes back and depress the clutch everything is so quite....and i noticed that it comes in 1st gear more actually it gets quieter as u r shifting into next gear...higher the gear less the noise...if its something else it shouldn't be coming while idling rite? it has to do something with tranny and clutch pedal...not disengaging / engaging properly? could be release bearing?
Old Sep 15, 2009 | 04:30 PM
  #42
BenStoked's Avatar
Jesus was a Zombie.
isb is going out. that's why Greeny doesn't have a VE, anymore.
Old Sep 15, 2009 | 04:40 PM
  #43
burhan92SE's Avatar
isb?...can u go in a lil more details?....plus if i shift to 4th gear where i should be shifting into 3rd theres no noise....
Old Sep 15, 2009 | 04:45 PM
  #44
internetautomar's Avatar
mod or sell?
well if you try and fill it from the side plug you are gonna have to hold the bottle sideways which makes it almost impossible to get the entire contents of the bottle to come out. pouring it into the speed sensor hole lets you have the bottle straight up and down.
that's why you slip a piece of hose over the nipple on the gear oils bottle cap and stick the other end in the hole.
Old Sep 15, 2009 | 04:46 PM
  #45
mod or sell?
Input shaft bearing.
Old Sep 15, 2009 | 05:01 PM
  #46
burhan92SE's Avatar
so is that it? i m sure it can be repaired...probably not cost effective even if u do it ur self?....and its not confirmed either that it is isb...
Old Sep 15, 2009 | 06:18 PM
  #47
CapedCadaver's Avatar
Call me Wookiee Goldberg
brian......... you and your logic.
anyhow.. if it grinds even at idle, and pushing the clutch is the only way to make it shut up (short of shutting the car off) then it's almost certainly the ISB.
It might be fairly pricey to have done at a shop, but in order to PROPERLY do it yourself, you would need a tool to remeasure the shims for the bearings so that your input shaft endplay is correct. and i'm not sure if it's a generic tool, or if the only place you can get it is from Nissan. Look at the section starting on MT-29 in the 94 FSM for more information about setting bearing preload and what equipment you would need to do it. And while you're in there might want to replace the input shaft oil seal as well to help prevent future leaks.
Old Sep 15, 2009 | 06:54 PM
  #48
burhan92SE's Avatar
simply i will have to take the tranny out eh?..
Old Sep 15, 2009 | 07:22 PM
  #49
James92SE's Avatar
2 VE's are better than one!
How about a video of this phenomenon? That would clear up all the conjecture
Old Sep 15, 2009 | 07:50 PM
  #50
basically. not terribly difficult tho... if you drain the tranny ahead of time (like last thing at night, then wake up and start working on the car in the morning) you can get the sucker out in 45 minutes flat. reinstallation takes slightly longer, but as long as you don't touch the clutch (ie so it stays dead-center over the flywheel) it usually lines up pretty easily when you are sliding it back on.
Old Sep 15, 2009 | 09:43 PM
  #51
burhan92SE's Avatar
ok..i will make a video of it
i get wut u saying....but its alot of work and i dont wanna do this mess at home...u have done it many times and it is easier to u...i m doing the manual tranny work on MAXIMA first time so its gonna take time for me....its different if i done it so many times and know exactly wat i m doing....i will jus take it to shop and diagnose it more..it might be something else...plus i will make a video as well....anyways lets keep trying to find a solution
Old Sep 16, 2009 | 07:34 AM
  #52
i could make you a list of instructions and assuming you have all the tools you'd need, if you followed it to the letter you could have the sucker out in 90 minutes tops. the only difference is the position of the intake and rear-side vacuum items and whatever that the VE has (compared to the VG) so you might have to move this-and-that out of the way to get to some of the bolts.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
MikesChevelle
Aug 7, 2015 05:57 PM
