Im think I have lost or am loosing my transmission!
Old Oct 11, 2009 | 12:07 AM
  #41
maxinout93's Avatar
Originally Posted by 1993-VG30E-GXE
What should I put the 2 settings to for this 2nd unknown used tranny I'm putting in next week, considering I'm doing city driving, mostly stop & go traffic, and city highway driving, but all on level ground most of the time. This used tranny will be in for about a yr.
I used to keep the OD button in the off position if i am doing mostly city driving at speeds below 55mph. That keeps the tranny from shifting into fourth gear and overdrive repeatedly, especially if youve got someone driving slow in front of you, I would keep it off. If you are going above 45 and 55 then I would suggest you turn the OD on like riding at highway speeds for a long period of time.
Old Oct 11, 2009 | 12:15 AM
  #42
maxinout93's Avatar
Update: I looked on car part.com and found some transmissions at really reasonable prices and not too far from where I live as I can go and pick one up next week. I will be in the process of taking out the tranny thats in the car now so when I get the other one it will be ready to install, and I can have the Max back on the road again. I just have one question. In the haynes manual section of how to remove the transmission, it has a section that says you have to "MARK THE RELATIONSHIP OF THE TORQUE CONVERTER TO THE DRIVE PLATE BEFORE REMOVAL. Also it says to do the same thing for the passenger side cv joint carrier bearing( the thing that that has three screws that have to come off in order to remove the pass. side cv axle. Is that really necessary?? I am kinda new to tranny removal so please help.
Old Oct 11, 2009 | 10:16 AM
  #43
1993-VG30E-GXE's Avatar
Neither are necessary. Before installation, you can measure the TQ to bellhousing flange and compare to the other side if you need to. It's mentioned in my notes. That's only if you tip the bellhousing on the tranny jack in the opposite direction - the tranny will naturally fall towards the heavy side (wheel well) so the TQ shouldn't move if you adj the tranny jack saddle thing properly. Make sure to find 2 short 2X4 wood or suitable wood to place the trans on when you store it, and also plug the holes with some plastic bag or something so creepy crawlies don't go in.
http://s398.photobucket.com/albums/p...02A%20REMOVAL/
Old Oct 11, 2009 | 10:21 AM
  #44
Oh one thing I forgot - If I were you I would wipe Anti-Seize inside that CV carrier bearing bracket, to prevent any future seizing. Mine was seized so badly I had to cut the RH Drive axle out of the car, then remove it outside on a vice with major heat.
Old Oct 14, 2009 | 11:08 AM
  #45
maxinout93's Avatar
I was wondering if when the tranny dies, would it be impossible to move the car? Im asking this because I want to move the car backwards. My friends and I tried to push the car backwards yesterday and the car would not move in either gear it would only creep forward a little bit in drive, tried to give it gas and the car wont revv over 2000 rpms. It seems as if the parking mechanism is locked as it wont budge at all!
Old Oct 14, 2009 | 05:02 PM
  #46
I don't know but if you really get stuck you can remove the axles then it will roll, and you need to remove them anyways, but it is a bit of work to put the knuckles back on just to roll it.
Old Oct 14, 2009 | 11:08 PM
  #47
maxinout93's Avatar
Thanks I will try that
Old Oct 20, 2009 | 06:14 PM
  #48
So what finally happened Maxinout - did you replace it or pay someone for the overhaul?
Curious the end cost.
Old Oct 21, 2009 | 11:27 AM
  #49
maxinout93's Avatar
Well to pay someone for the overhaul would cost more than what im willing to spend on the car. Because there are alot of 3rd gens for sale around here for pretty cheap, most less than $1000. But Ive put alot of money into mine to just let it go for $500 with a bad tranny, or to the salvage yard. So I have been searching for a tranny, and Ive had some luck so far, so All I have to do is start taking mine out once I get the other tranny home. I was wondering though, would the tranny fit in an average car trunk?? I have to drive like 3 hours to get it. The 2 cars are a mazda 626 4 cylinder, or a 2000 nissan maxima, that I plan to put it in. I dont want to overload the cars.
Old Oct 21, 2009 | 11:39 AM
  #50
Stwodahorty's Avatar
theres some trannys on ebay lol they can possibly ship it to your mechanic, youd probably should ask the mechanic in advance if he can put it on for u that way he can accept the package.
Old Oct 22, 2009 | 09:50 AM
  #51
maxinout93's Avatar
sounds great, Ill look into that asap, because I miss my Max so much!
Old Oct 23, 2009 | 03:16 PM
  #52
It's so easy to put it in, just do it yourself and don't pay anyone. If you need my help I can assist you,just email me. If you really need me to I can go outside and measure the dimensions for you to see if it will go in the trunk. It did fit in the trunk of the Maxima.
Old Oct 24, 2009 | 12:46 PM
  #53
maxinout93's Avatar
Thanks I think I will try to put it in myself, as I am buying more tools to do the job, I think if I do have to travel to get the tranny, I will more than likely put it the trunk of the 99 mazda 626 4 cylinder, or a 2000 nissan maxima. Will be doing it in about a week or so.
Old Nov 15, 2009 | 08:43 AM
  #54
maxinout93's Avatar
Well I found a few good deals on a tranny. So far I have stripped the car down to where the transmission bolts are accesseble, and have managed to loosen about three of them from the top. I will probaly pay someone to do the rest of the job as it seems a little complicated in a sense as far as taking the mounts loose and the crossmember. Hope to get it rolling soon!
Old Nov 16, 2009 | 12:52 AM
  #55
Pictures of the mounts if they'll help. Don't need to touch the crossmember mounts. As well don't loosen any mounts if nothing is supporting the tranny.
Old Nov 16, 2009 | 12:55 AM
  #56
Old Nov 16, 2009 | 11:51 AM
  #57
maxinout93's Avatar
Ohh Ok I see what you are saying! Im gonna drain the fluid and take the axles out today, those pictures are giving me some ideas of painting my intake manifold lol. I miss my car though, taking the bus and catching rides to work is starting to get annoying! I will go out and take some pictures of my progress and post them up soon.
Old Nov 16, 2009 | 11:55 AM
  #58
maxinout93's Avatar
those bolts on the top rear transmission mount seem like a B#### to remove. I dont have any air tools or access to them, I know they may make the job easier, but would just regular tools get the job accomplished? I thought I saw someone post a list of tool designed for transmission removal.
Old Nov 16, 2009 | 07:28 PM
  #59
You don't need to remove that top part of the mount, only if you were to recondition it / paint it etc.....
And even then, you remove it once the transmission is removed from the car. do you see the studs hanging down, there are two of them in the photo, for that rear mount. Those bolt into the bottom piece of the mount that isn't in my photo. To separate that rear mount when you do the removal, all you do is remove the 3 X M10 cap screws that are visible head on (that attach the lower part of the mount to the trans) by looking through the wheel well when you remove the splash panel. then you remove those 2 X M10 hex nuts from those dangling studs in my photo.
The front transmission mount, you would separate it so it looks like in my photo with the top part still attached to the chassis. You separate it at the mid point via 3 X M10 cap screws. Once you lower the tranny then you can unbolt it from the front of the tranny.
Old Nov 16, 2009 | 07:37 PM
  #60
It can be done the manual way with just a breaker bar but you have to be REALLY careful. Sometimes the breaker bar can cause damage like it killed the weld anchor on my transverse link gusset that is inside the chassis. If I were you I would leave that top part of the mount on the chassis. If you break the weld anchor, your are adding on many hrs if not days to your job.
Problem with the breaker bar is if it's seized, when you put torque on it, it bends the weld anchor inside, so as soon as you detect it's seized, stop with the breaker bar. With the impact wrench, it spins it almost stationary, so it can help minimize the damage in my opinion.
I would just leave it alone, as those M12 cap screws for that anchor are Super Fine Thread, and they strip even easier.
Old Nov 23, 2009 | 04:02 PM
  #61
maxinout93's Avatar
Wow I did not realize how difficult it is to remove the driver side cv joint! Getting it to slide out of the hub was a breeze, trying to get it to come out of the transmission is a whole nother thing! I tried to pull it out, and I tried to to get it out with a pickle fork, and even tried to use a small regular sized flat head screw driver and got no results. It was getting dark and cold so I just put it all back togather! My intensions were to take the axles out of the car and just put the nuckle on with the wheel so I could get the car to roll back wards by pushing it, since in the current situation, it is stuck and will not budge.
Old Nov 23, 2009 | 05:12 PM
  #62
I used an iron chisel and iron mallet, and pried it by hammering the chisel in between that CV Joint housing thing and the side of the tranny. It hadn't been removed for 16 yrs, and it did come out with the prying method. But not just prying by hand, it was hammering the chisel with the mallet that got it to come out. Of course don't pound it too hard.
(another thing you may want to see if possible, is if you can poke it out from the passenger side through that hole, that's if there isn't something blocking it. You might be able to stick a phillips screw driver through there, then tap the screwdriver head and it could pop it out. Can't remember if there's gears in the way though)
Old Nov 23, 2009 | 06:06 PM
  #63
maxinout93's Avatar
the second method sounds a little easier, cause the haynes manual said to do it that way also. Im assuming that the cv joint, like yours has been in there since the car was built 16 years ago and is stuck to the transmission. I only changed the passenger side axle since ive owned the car, and was in the process of changing the driver side cause of a vibration at speeds of over 65mph after putting new tie rod ends on the car didnt get rid of the problem. I was trying to avoid the passenger side axle because of that infamous carrier bearing crap that everyone was talking about, but it looks like I will have to fight with that side tomarro hopefully Its a warm day tomarro where I can get something done!
Old Aug 14, 2011 | 11:54 AM
  #64
eugene89us's Avatar
I had a similar problem with my tranny lacking any powert until I replaced my TCM. Now it works great - thank God a $20 solution worked like a charm.
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Pied
Sep 26, 2015 03:29 PM
