eibach pro kit
Old Nov 30, 2001 | 04:03 PM
maximum3rdgen's Avatar
eibach pro kit
if i get the eiback prokit will 17" rims with 45 series tires fit ok or do i need 35 or wut? thanks
Old Nov 30, 2001 | 04:07 PM
Bucktown's Avatar
you will have plenty of room with 17" rims and 45 series tires with the eibach pro kit. i used to haev that combo. there is still a lot of fender gap, so i switched to intrax which drops it another half inch, and there is still enough room.
Old Nov 30, 2001 | 06:12 PM
Bman's Avatar
As long as the tire/wheel combo you have now fits on the car without rubbing, they'll fit the same with the Eibachs. This assumes the tire you have now isn't a whole lot taller than the stock tire, which is what matters. Theoretically you should be able to drive around with NO springs and they won't rub - otherwise your tire/wheel combo is probably wrong.
Old Dec 1, 2001 | 10:38 AM
HoJo's Avatar
Originally posted by Bman
[BTheoretically you should be able to drive around with NO springs and they won't rub[/B]
Theoretically, if you took out the springs the car would be resting on the top of the tire, Theoretically
Old Dec 1, 2001 | 12:29 PM
dmontzsta's Avatar
Ford Only.
What up Buck? I have a question for you. Did you notice a drop in performance/handling when you switched from Eibach to Intrax?
Old Dec 2, 2001 | 12:54 AM
Bucktown's Avatar
yeah, it's a little more bouncy and you can feel the bumps more. but that's expected with a lower drop and considering that eibachs are one of the best handling springs on the market. there's also a wierd noise when i have my foot on the gas and make right turns, but that's something else that i can't figure out.
Old Dec 2, 2001 | 02:41 AM
Bman's Avatar
Errr waitaminute... I always thought that's what the bump stops were for (aren't ours part of the strut?). Otherwise every time you bottom out the suspension on a big bump you'd be hearing this horrible scraping noise.
Old Dec 2, 2001 | 09:06 AM
HoJo's Avatar
Kind of. The bumpstops being a soft hollow rubber couldn't support the 2800 or so pounds of the car resting on them. They would flatten out.
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
Socalstillen
Sep 26, 2015 12:01 PM
