VE timing chain info
No. The piece was "eaten" likely by being stationary and the friction of everything that was still moving. If the chain "ate" anything, we'd be having a different conversation.
I got mine from a local dealer at employee priceing, about $50 each. The whole unit (VTC) was $150 my price.
I finally got the engine back together and fired it up. I still have a slight VTC noise. It goes away when I ground the solinoid. So... with the results I received by rebuilding mine, I'd recomend you just buy a whole new unit. The rebuild kit comes with a new spring, new oring, new seal, and new end cap. There are other instructions around including a TSB on how to rebuild them.
I second what JC is saying, count yourself lucky there was no further damage to the timming chain system.
It will help if you call the dealer and get the part number, or do a search for the part number here and then plug it in to the nissanparts.org.
Ah, what the heck... Here is a thread that will show you pictures of the kit, as well as give you part numbers.
http://forums.maxima.org/1st-3rd-gen...ensioners.html
And here is the rebuild kit on nissanparts.org:
http://www.trademotion.com/partlocat...gOEM&siteid=49
Dang, they are getting cheaper.
My head tells me to ignore the chain marks since they won't line up again after the first revolution but I am torn as to why would the instructions say to use the chain if it is wrong. Also note that the instructions say 12 rollers between cam marks, I have to decrease it to 11 rollers to get the marks to line up.
As to the silver links lining up with the sprocket marks (dots), they will only line up every few revolutions (can't remember exact number), so if you keep turning the crank, they will line up again at some point.
I could have used that reasurance last week!
This is what I ended up doing. The engine runs so much better! Nice and strong. And the process started the same way as it did for you. Took the VTCs off without making marks. I saw the marks on the cam and I assumed they lined up with the arrows. Then I couldn't get the cams to line up with the arrows like I thought during re-assymbly. I guess I'm to used to timing belts where they have timing marks that line up.
if someone wouldn't mind refreshing me as to where the piston is 120 degrees before TDC I would appreciate the info. Lined up all chains and marks just want to make sure that the bottom end is in sync with the top end.
No. 1 at 120 deg btdc just gets the pistons all down enough in their holes so that there's no valve contact when you put heads/cams back on until you can get everything buttoned down and get the cams where they need to be.
To ensure bottom end sync with top end, you use the crang timing mark at TDC. The only reason the instruction reference 120 BTDC is that is where you want to put the chain on for the rear cams. At 120 BTDC like JC said, the pistons are not all the way up as to not cause interferance, and none of the rear valves are depressed which takes the presure off of the cams.
With the Crank at TDC #1 and #4 piston should be all the way up (highest point in travel). The cams marks willl only line up every other revolution at TDC. The cams rotate 1/2 the speed as the Crankshaft.
It would be easier if you took them off. Plus you could check to see if theres any other problems or future issues.
The crank is set 120 degrees BTDC so that the slack of the chain is taken out while turning and applying pressure to the tensioners and the marks should be aligned to thier perspective points
" Turn crankshaft until No. 1 piston is set at approximately 120 deg. before T.D.C. on compression stroke to prevent interference of valves and pistons." This is before #18 that says "Install Cylinder heads...". By the book, the cams are then installed and positioned, the rear VTC, rear sprocket (with chain understood) and rear tensioner. #24 says turn crank to TDC, then the front gets done in further steps.
The tensioners take up any slack in the chain when they're installed, and I'm not sure what you mean "applying pressure to the tensioners".
Yeah because when you unhook the latch for the tensioner it engages. But I think what CMax03 is talking about is when oil is pumped up to the tensioner they stiffen up even more. But I'm not sure if so or not that difference is a tooth on the sprocket or not. I doubt it.
There is a way to use an air compressor to put pressure in the cylinder to hold up the valves while you pull the springs off to replace the seals, but you probably already know this since you've done one already.
Hey guys I just put the the car together after rebuilding everything even the heads and I'll put pictures later, but I have a question:
Is it normal for the car to run like a DRAGSTER under 3000 RPMs if the VTC solenoids are disconnected ? Do I have to reopen the engine and re-do the timing or it's just that the VTC are not on.
The connectors of the VTC solenoids are in bad shape and probably I have to REPLACE them. (I don't think they make any connection when I connect them)
Rebuild work:
$22 - Parts cleaner solvent
$65 - Full gasket set
$60 - VTC spring kits, 23 each + S&H
$53 - VTC, Chain tensioner and Knock sensor from junkyard
$13 - main front seal
$7 - Power steering fluid
$7 - Vacuum hoses
$4 - gasket RTV (for oil sealing)
$3 - water pump RTV (for water sealing)
$4 - valve polishing compound
$1 - plumber T-shaped adapter - for aiding the valve spring compressor
-Knock sensor - from junkyard from a 97 Maxima(they are all the same) - when I removed the old KS it crumbled in my fingers. Looks like WASHING THE ENGINE cracks the plastic, a lot of water collects there and I had to scrape half an Inch of RUST !!!
-Vacuum hoses - new
-Valve cover gaskets - new
-Plenum, intake, throttle body gaskets - new
-PCV valve - cleaned
-Lifters - cleaned (like new)
-Chain tensioners - cleaned (with parts cleaner - one was in good shape, one got from the junkyard pretty good shape)
-VTC - one in good shape, one from the junkyard - both look like brand new from the dealership. Cleaned and Changed the spring/seal/cap anyway, just in case.
-Valve seals - new
-Head gaskets - new
-Exhaust gaskets - new
-Main front seal - new
-Alternator - cleaned
-Power steering pump - new (they looks like they degrade easily)
$7 - Vacuum hoses
-Vacuum hoses - new
-Valve seals - new
-Head gaskets - new
Here are some pictures from the rebuild:
http://i911.photobucket.com/albums/a...o/DSC00649.jpg
http://i911.photobucket.com/albums/a...o/DSC00650.jpg
http://i911.photobucket.com/albums/a...o/DSC00651.jpg
http://i911.photobucket.com/albums/a...o/DSC00652.jpg
http://i911.photobucket.com/albums/a...o/DSC00683.jpg
http://i911.photobucket.com/albums/a...o/DSC00684.jpg
http://i911.photobucket.com/albums/a...o/DSC00685.jpg
http://i911.photobucket.com/albums/a...o/DSC00686.jpg
http://i911.photobucket.com/albums/a...o/DSC00687.jpg
http://i911.photobucket.com/albums/a...o/DSC00688.jpg
http://i911.photobucket.com/albums/a...o/DSC00690.jpg
http://i911.photobucket.com/albums/a...o/DSC00691.jpg
http://i911.photobucket.com/albums/a...o/DSC00692.jpg
http://i911.photobucket.com/albums/a...o/DSC00693.jpg
http://i911.photobucket.com/albums/a...o/DSC00694.jpg
http://i911.photobucket.com/albums/a...o/DSC00695.jpg
http://i911.photobucket.com/albums/a...o/DSC00696.jpg
http://i911.photobucket.com/albums/a...o/DSC00697.jpg
http://i911.photobucket.com/albums/a...o/DSC00698.jpg
http://i911.photobucket.com/albums/a...o/DSC00699.jpg
P.S. By looking at pictures of other guys rebuilds - it gave me confidence to rebuild mine, so I'm sharing mine. Hope it helps somebody else too.
What do you mean run like a dragster??? When the car is idling, the VTC solinoids are not "on". So they are in the same state as if you didn't have them connected. Under load, at about 2500RPMs, the soiliniods are supplied with ground and activated. This allows them to be presurized by oil and advance the Intake cam by about 10 degrees.
So to answer your question, no, having the VTC solinoids disconected would not effect the normal operation of the engine at idle, or even below the aprox 2500 rpms. Under load and in the higher rpms the engine would run as if it were retarded, literally. So it would be slower to rev.
I haven't looked at the pictures yes, but sounds like you did the right thing by replaceing the knock sensor. Did this resolve your VTC noise? When I rebuilt mine it did not. So I have just grounded mine, I'm not ready to put another $300 into the car to replace the VTCs with new ones.
