Is there a strtup proceedure with new VTC/Chains/Tensioners?
Old Oct 30, 2009 | 05:49 PM
JC93SE's Avatar
I just replaced VTCs, chains and three tensioners. Is there something special I need to do when I get around to firing it up the first time? (have other things to do first) Will the tensioners pump right up when the oil pressure comes up or do I need to stay with it?
I ask because I've heard about someone firing up a VQ and having to hold RPMs at 2000 until the noises go away, or about chains whiplashing the first time after revving, etc. Stuff like that.
Or, is it just start it and have a nice day?
Old Oct 30, 2009 | 07:23 PM
vernk's Avatar
I would pull the plugs (be sure to cover holes with a rag so you don't suck anything into the cylinder) and turn over by hand till oil is circulated though out the engine so that the tensioners are primed, I have read of the timing chain jumping due to the tensioners being loose.
Old Oct 30, 2009 | 08:56 PM
505max94se's Avatar
You don't have to prime the engine, but I would recommend unplugging the power transistor unit and then crank it for about 30 seconds. Then you can start it, but just don't shut it off immediately even if it sounds really bad.
Old Oct 31, 2009 | 05:30 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
wouldn't you maybe want to unplug the injectors too? so that you don't flood the cylinders with gas while cranking it
Old Oct 31, 2009 | 10:45 AM
James92SE's Avatar
2 VE's are better than one!
On my JDM (it has new VTC's) I just recently started up I pulled the plugs and cranked it over by hand 5 or 6 times first. When I started it up, the thing sounded TERRIBLE. It had me quite scared to be honest. I've started some VE's up before that sounded awful for about 5-10 seconds before quieting down, but this sucker sounded like the heads/VTC's were going to explode for about 5 full minutes. It finally quieted down and hasn't made a peep since.
Old Oct 31, 2009 | 12:11 PM
KRRZ350's Avatar
If ve's are anything like VQ's, priming by pulling plugs/fuel isn't a good idea.
Old Oct 31, 2009 | 01:52 PM
wpendl1's Avatar
I didn't do anything special after I rebuilt my VTCs. I only pulled the upper tentioners, but before starting it, I left the CPS unplugged while I cranked it over a few time with the starter. This seems to control the fuel pump and would keep fuel from being spit into the cylinders and of course there would be no spark as well.
Old Oct 31, 2009 | 05:42 PM
505max94se's Avatar
I guess, but I doubt that the engine would flood from just cranking it for 30 seconds. Unplugging the cps would probably be a better idea.
Every time that I replaced the tensioners and vtc's in a ve, I just fire it and I haven't had any problems.
Old Oct 31, 2009 | 09:30 PM
JC93SE's Avatar
Why do you say that?
Old Oct 31, 2009 | 09:32 PM
JC93SE's Avatar
I have also pulled the fuel rails. If I crank it before starting it, I'll pull the fuse for the fuel pump before i first turn the key.
monty31
65
Jun 6, 2019 11:42 AM
SSJRICH
May 1, 2013 02:54 PM
Self
May 22, 2011 07:51 AM
MOBOY
Sep 5, 2001 01:37 PM
