tapping exhaust gas sensor for air/fuel meter?
Old Dec 3, 2001 | 04:03 AM
ngthing's Avatar
is this the correct sensor wire to tap, the exhaust gas sensor?
Old Dec 3, 2001 | 12:10 PM
HoJo's Avatar
Are you talking about the O2 sensor? It depends on the AFM. Some will run off of the stock O2 sensor, but most AFM's need a wide band O2 sensor. You would need to put another fitting on the Y-pipe for it.
Old Dec 3, 2001 | 03:50 PM
ngthing's Avatar
I don't know if the EG sensor is the same as the O2 sensor, the EG sensor is located in the engine bay. I'm running a AF meter off whateverI tap.
Old Dec 3, 2001 | 03:55 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
just get under your car and tap the wire directly from the sensor...my mechanic did mine for free when he changed my brakes. I think its the white wire, but I'm not 100%!
Old Dec 3, 2001 | 05:15 PM
ngthing's Avatar
would it be too much of meto ask you go down and check?
anybody have any otheri nput on the EG sensor?
Old Dec 3, 2001 | 05:49 PM
DA-MAX's Avatar
give me till tommorow, its 9pm and ~40 degrees over here on the east coast....I ain't getting under the car anytime tonight!
Old Dec 3, 2001 | 05:52 PM
DA-MAX's Avatar
and oh yeah, its Pin29 on the ECU, so if you wanna tap it inside the car you can do that to!
220k+ A32
Sep 11, 2015 02:18 AM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
