auto tran. problem
Old Dec 3, 2001 | 12:14 PM
matermax90's Avatar
auto tran. problem
heads up to those with 3rd generation maximas. get transmission checked out for metal chips. torque converter spits small metal chips into clutch chamber and eats away the walls, therfore lowering pressures inabling the car to shift through 3 gear.
Old Dec 3, 2001 | 12:20 PM
dirksmoothe1's Avatar
Re: auto tran. problem
is that for VE autos or VG autos?
Old Dec 3, 2001 | 02:56 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Re: auto tran. problem
I doubt it matters both have TCs so it will happen in both! I know most of our cars have a magnet on the drain tube to help with this also.....
Old Dec 3, 2001 | 03:30 PM
Re: Re: Re: auto tran. problem
yeah, but both don't have TC's that spit out metal shards...
Old Dec 3, 2001 | 03:51 PM
DA-MAX's Avatar
Re: Re: Re: Re: auto tran. problem
huh?? any TC will spit out metal shards if its beat on enough! and besides some of the later VG trannys(post ~'92) are built the same as the VE tranny minus VSLD according to the numbers!
Old Dec 3, 2001 | 03:56 PM
Re: Re: Re: Re: Re: auto tran. problem
I will guess by his name that he has a 90, which raises the question... is his the same as mine?
I am not trying to be a smart a s s, but actually trying to get knowledge... I didn't know that TC's did that if they are beat on... sorry DA-MAX...
Old Dec 3, 2001 | 04:06 PM
DA-MAX's Avatar
thats another advantage of Protorques high stall converter, its internal components are welded opposed to the OEM converters "free floating" internals, I'm pretty sure that cuts down on metal shavings as well.
and the only reason I know that some of the later models are the same is because at one time Don was offering his VB mod for the VE Maxima and if I remember correctly a few of the late model 3rd gen GXE owners actually had trannys compatible with Dons VB(thus the same VE tranny minus VLSD??)....I also heard that after '92, NIssan rebuilt the GXE trannies since they had so many probs with the 89-91's!
Old Dec 3, 2001 | 05:22 PM
DanNY's Avatar
Ad·min·is·tra·tor
hence the reason i run a filter. trying to keep the wear down.
Old Dec 3, 2001 | 05:28 PM
Jeff92se's Avatar
I'm needing a caw
If you guys are that worried, get the tranny oil analyzed every once in awhile by Blackstone or whoever
Old Dec 3, 2001 | 05:46 PM
DA-MAX's Avatar
Dan, about the filter how did you hook it up???
I'm guessing...cooler-->filter-->into tranny....right?? which model is it?? I've seen a PermaCool model in my Jegs catalog, is that the one??
Old Dec 3, 2001 | 06:26 PM
DanNY's Avatar
Ad·min·is·tra·tor
no no...filter 1st..then cooler. u want to keep the cooler clean so it won't clog.
i have a PermaCool clone set up...it's almost the same.
Old Dec 4, 2001 | 02:26 PM
matermax90's Avatar
i dont know if my car is a VG or VE
how do i find that out?
i jus recommend that everyone gets there tranny checked for that
...and thanx da-max for the info on the protorques TG, ill look in to that
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
slowlifer
Sep 8, 2015 05:53 AM
