F@(&!#g injectors again........
Old Dec 30, 2009 | 06:38 AM
  #41
litezoner's Avatar
Originally Posted by svnd
Same problem here. Seems that 2 of the injectors is gone and the dealer is saying it doesn't cost extra labor to replace all the injectors. $175 per injector for nissan orig and $100 for non-nissan. $550 for labor. Is this a reasonable price?
Not too difficult to do yourself, Just buy an intake gasket set. That price is way too high for labor and the injectors, They are hosing you for sure.
Old Dec 30, 2009 | 06:39 AM
  #42
internetautomar's Avatar
mod or sell?
Originally Posted by Hectic
High price for both the OEM and AM injectors. And $550 is a lot for a job that isn't all that difficult.
OP: Those 92+ injectors really are badly designed and it's easy to pinch and spring leaks in the o-rings which floods the cylinder, which i'm guessing is your problem, new OEM injector isn't going to go out in 2 years. Course if it was installed improperly, it probably would have started to leak a lot sooner than this.
the one that failed for the OP is the one the mechanic sold him. the other 5 were ok still. He got a new one from the same source as he bought the other 5 (me) and he should be good to go.
Old Jan 2, 2010 | 01:54 PM
  #43
G3Karl's Avatar
I have the new injector in and the car runs like a champ again. I also replaced the rubber crossover fuel lines and clamps, plus new upper intake manifold gaskets.
Took about 2 hours.
Phew......
Old Jan 2, 2010 | 06:10 PM
  #44
Stwodahorty's Avatar
Took about 2 hours.
Phew......
i just changed my intake manifold gasket + an injector too, and my exhaust manifold gasket. runs great however for some reason its a bit shakey, probably gonna change my spark wires, distributor cap, and ignition rotor soon.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
