Engine code 35 for 93 maxima
Old Dec 28, 2009 | 04:50 PM
walterh's Avatar
My check engine light came on today and I am getting a code 35 - Exhaust gas temperature sensor (California models). Can someone please tell me where this sensor is located? Thanks
Old Dec 28, 2009 | 05:41 PM
BenStoked's Avatar
Jesus was a Zombie.
If you have a 94 FSM, it's on pg "EF & EC-5"
http://www.nicoclub.com/FSM/maxima/1994/
(ec.pdf from that site)
Old Dec 28, 2009 | 06:07 PM
walterh's Avatar
thanks. does this sensor affect performance?
Old Jan 5, 2010 | 01:36 PM
walterh's Avatar
Ok, I seem to not have a EGR Temp sensor. Why would it give me this code?????
Old Jan 13, 2010 | 10:23 AM
walterh's Avatar
Anyone????
Old Jan 13, 2010 | 10:35 AM
Matt93SE's Avatar
STFU n00b!
IF you have a cali spec ECU and a non-cali engine, then you could get it.... but otherwise I don't know.
Sure it's not a code 53? (just throwing bones...)
Old Jan 13, 2010 | 12:08 PM
walterh's Avatar
Well, the red light blinks 3 times, and the green light blinks 5 times. I bought this car a few months ago, and the engine light has been on since then. I looked and don't have a Exhaust Gas Temperature Sensor. I wonder if the ECU has been replaced?
Old Jan 13, 2010 | 02:20 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
on the VIN plate under the hood, there should be a model info number that has the format "x L J 3 0 x x E x" which you can decode on page GI-15 here http://www.nicoclub.com/FSM/maxima/1994/gi.pdf
that will tell you what engine/ecu combo your car SHOULD have.
Old Jan 13, 2010 | 02:24 PM
Matt93SE's Avatar
STFU n00b!
What does the light on the dash do when you put the ECU in diagnostic mode?
Old Jan 13, 2010 | 04:46 PM
walterh's Avatar
Ok, well my car is a non-cali GXE. The light on the dash flashes one time then flashes 3 times. I'm not sure if it flashes once then 3 times or vice versa. Any ideas????
Old Jan 14, 2010 | 12:04 PM
walterh's Avatar
Anyone?????
Old Jan 14, 2010 | 12:13 PM
Matt93SE's Avatar
STFU n00b!
Where is the long pause? it will be either:
flash........flash..flash..flash.................. ...........................repeat
or
flash..flash..flash..........flash................ ...........................repeat
Old Jan 14, 2010 | 01:06 PM
walterh's Avatar
flash........flash..flash..flash. That would be the coolant temp sensor, but why am I getting the code 35 from the ECU?
Old Jan 14, 2010 | 01:10 PM
Matt93SE's Avatar
STFU n00b!
You don't read the red/green ones. I'm not exactly sure what those do. BUt if you put the ECU in diagnostic mode, you'll get the same code from the blinking light on the dash and from the red light blinking on the ECU.
Coolant temp sensor is very important on these engines for maintaining drivability. without it, the engine will run very very rich and possibly stall out from flooding. check/replace the temp sensor and see where you go from there.
IIRC, you were having a problem with it in another thread with the radiator fans always on, or was that someone else?
edit... nvm.. that was someone else.
are YOUR radiator fans always on?
Old Jan 14, 2010 | 01:59 PM
walterh's Avatar
Well, when I was at the pull-a-part, I grabbed a couple of CTS and this one must not be working properly. I will switch it out. So I am supposed to read the blinks from the check engine light itself? I didn't know that. I've been reading the red/green light. Before I changed the CTS my check engine light was still on. Why would I be getting the 35 code????
Old Jan 14, 2010 | 02:32 PM
Matt93SE's Avatar
STFU n00b!
yeah... read it from the check engine light or from the red light on the ECU when you put it in diag mode. when the engine is just running, I don't know what the blinky lights mean. been a while since I've had to mess with it.
you could still have problems with another sensor somewhere else causing the CEL, but I'm not sure what a code 35 would be doing on your car...
Old Jan 14, 2010 | 02:33 PM
BenStoked's Avatar
Jesus was a Zombie.
why buy a used and questionable quality part, when you can get a new one for $15?
I could understand a MAF, or such, but cheap sensors... it's like getting used t-belts; not something you really ought to do.
Old Jan 14, 2010 | 02:44 PM
walterh's Avatar
I will go buy a new one. I just grabbed them while I was there. Thanks for all your help!!!!
Old Jan 14, 2010 | 02:48 PM
Matt, remember tho that on VG's 5-mode ECU you DO use the red and green lights together
http://s164.photobucket.com/albums/u...t=MVI_2370.flv
(this shows a 55)
when the car is running and you are not touching the screw, the green light indicates o2 sensor polling.
Old Jan 21, 2010 | 11:27 AM
mrgooch42's Avatar
Good work.
Old Jan 21, 2010 | 11:33 AM
Matt93SE's Avatar
STFU n00b!
(this shows a 55)
okie dokie... never had to diagnose a VG this way so that's something new to me.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
