Pre-5spd swap questions
Old Mar 2, 2010 | 07:00 AM
  #81
ve30max's Avatar
He emerges from his man cave!
I wasn't expecting anything from you, just curious if there was an easy explanation. I was hoping marke would follow up with a correct explanation of which wires are go where, since he discovered the appropriate setup, but he has a functioning car and has no use for us, yet............
I figured I would ask before I dive into the FSM, which probably wouldn't hurt me, but easy is as easy does.
Would using these clutch components pose a problem, such as destroying anything other than themselves? I can deal with wearing them down more, just to have to replace them eventually, but if they potentially will fail and cause disastrous effects, I may need a new one huh?
I appreciate the help, and I have atleast 3 weeks more until this information will be vital, so no rush. I find it easier to use the little yellow blobs to encourage a more fun atmosphere. If I had said "HELP!!" I may not have received a kind answer...........
Old Mar 2, 2010 | 08:54 AM
  #82
marke's Avatar
I just used the red/black wire instead of the yellow/black one.
My flywheel had micro-cracks in it like yours, but when I had it resurfaced they went away.
Old Mar 2, 2010 | 09:10 AM
  #83
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea i figured that out when i did mine. the FSM had a misprint (showing the back-up lamp attached to the y/b wire instead of the r/b wire)
Old Mar 2, 2010 | 09:30 AM
  #84
ve30max's Avatar
Originally Posted by ve30max
So Caped (and you other swappers),
When looking at this and the brake cancel switch/clutch cancel switch diagram you posted previously, I think I have an okay understanding of what to do. Except for two minor questions (#3 and #4).
  1. rearrange the harness of the m/t to look like the second pic
    • so that it matches up with the a/t plug in form and function
  2. extract one wire from the brake cancel switch plug and place it into the clutch cancel switch
    • then link the two connections left open with a wire, or two as shown in the pic
  3. the wires extracted from the harness in the first pic (the a/t inhibitor switch) are the same G and Y/B wires in the second?
    • I am guessing the sensing device that detects the N/R position is inside the m/t?
  4. I am guessing the clutch cancel switch is the one closer to the firewall, but this would leave the one that is engaged with the clutch "UP" out of the loop, unless I wired it like you did Caped, correct?
    • I am interested if your setup provides a more reasonable clutch function; does this setup disturb any components like the TOB or either cylinders b/c of the small amount of pressure present; or do you think it balances out naturally without the spring (is there no pressure)?
I am sorry for all the silly questions, but I am naturally curious.
I hope my description isn't too far off and my questions don't involve too much misinformation, if any, but I know I can't be too far from the truth.
So getting back to these questions.
  1. With the wires appropriately arranged (r/b instead of y/b) the pic is correct and points 1 and 2 in the quoted post are correct, from what I can see.
  2. Question 3 is answered by the past few posts, and thanks marke for the confirmation and testimony on the flywheel.
  3. Question 4 and its sub question has yet to be answered directly, but it is explained in other threads so I kinda understand why you would take the spring off and wire the brake cancel switch to the clutch sensor furthest from the firewall.
    • So whaddup wit dat Caped?
Old Mar 2, 2010 | 09:47 AM
  #85
k here's the "fixed" pic lol
the green/black is naturally present in the 4-pin connector and so is the brown one. just move them to appropriate positions shown in the pic
the green one is the thicker green wire from the 6-pin connector
the red/black one is also from the 6-pin connector
the clutch cancel switch (as see in the graphic i posted a page or so ago) is the 'upper' one. the 'lower' switch (firewall) is the one that you need to send thru the firewall to wire in parallel with the green/black and brown wires.
the weight of the pedal itself is SO minute compared to the weight that you put on the pedal when pressing it. I never had any issues with strain or slippage when using a springless pedal, but imo it improves feel and feedback as well as engaging smoother. I just used the adjuster on the master cylinder rod to set the pedal height so that it was just high enough to keep the cruise control switch pressed. no clunk, and a smooth taper. just adjust the clutch-start stopper up a bit so that there isn't alot of dead freeplay at the bottom of the pedal travel.
Old Mar 2, 2010 | 12:35 PM
  #86
ve30max's Avatar
From what I can gather, this is what it should look like, and how the clutch start switch should be wired. It basically reconfirms what you have already drawn and taken pictures of.
I will look at my pedal and the switches more to fully understand the last paragraph and perhaps replicate the setup you have.
Old Mar 3, 2010 | 08:55 AM
  #87
ve30max's Avatar
I guess my diagram is inferior if I don't get feedback.
Old Mar 3, 2010 | 01:37 PM
  #88
@ wookiee head
actually technically the cruise control wiring doesn't go through the firewall, it goes to the little ASCD control unit up under the dash. wiring from that goes through the firewall.
but everything else looks right. just remember that the green/black and brown are a pair and that the thick green and the red/black are a pair. the reason the thick wire is important cuz that's actually the power source for the backup lights. there's no relays or anything further down the line.
now.. as far as the pedal spring thing.. basically the switches are threaded for adjustilbity. you can adjust them to set the upper and lower boundaries of the pedal travel. so what I would do is take the return spring off, then reinstall the pedal, and use the threaded rod coming thru the firewall to set the pedal height where you want it after the clutch is bled). then once you have it where you want it, adjust the cruise control switch so that the button touches the pad, but the metal shell of the switch has about 1mm gap before touching the green pad. then once you have the swap finished you can set the start switch about a half inch past where the clutch fully disengages. that way you don't have a bunch of useless travel at the bottom of the pedal.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Johnny9595
Sep 3, 2015 05:18 AM
