Can someone tell me what the purpose of this part is
Old Feb 22, 2010 | 10:42 AM
vmarques82's Avatar
I noticed i have a leak around one of the bends on this part # 30650+A.
According to Nissan it is no longer available. Question is what is its purpose and can i just cap off both ends seeing as how it comes out of and goes back into same block? Or do i have to make another line and if that is the case does it need to be nearly as long?
When i press the clutch it goes right to the floor and does not come back up and i can see the fluid pissing right around one of the bends that has a pin hole leak in it.
Attached Thumbnails Can someone tell me what the purpose of this part is-clutch-line.jpg
Old Feb 22, 2010 | 10:50 AM
BenStoked's Avatar
Jesus was a Zombie.
supposedly, it's some sort of coolant-type pipe, or something.
alot of people who do 5-speed swaps bypass it.
Old Feb 22, 2010 | 12:21 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
coolant? really? are you smoking crack again?
it's a damper to make the clutch "feel" better, or so they say. maybe to reduce vibration coming back through the pedal or something. you can just attach the rubber clutch hose directly to the hardline coming form the master cylinder if you want. makes it easier to bleed as well.
Old Feb 22, 2010 | 01:15 PM
BenStoked's Avatar
Jesus was a Zombie.
hell, I never did care what it did, I just know I never have had clutch problems, so I didn't bother noting what it's purpose is (I know now)
regardless, it can be safely bypassed.
Old Feb 22, 2010 | 07:42 PM
GRNMAXDMON's Avatar
i threw it in there when i did my 5speed swap. i did have altercations with my clutch a few times here and there but it was just the damn slave cylinder. i have thought about bypassing it but got lazy and forgot about it. maybe when i move back i'll take care of it.
Old Feb 23, 2010 | 12:27 PM
vmarques82's Avatar
How can i properly bypass this?
Is it by capping the two outlet ports?
Making a short jumper line to go from one outlet to other?
Remove block all together?
Old Feb 23, 2010 | 01:24 PM
use a flare nut wrench and just unhook the input line (coming from the clutch master cylinder) and the rubber line from the output line. then just attach the rubber line directly to the input line after removing the whole block thingy.
edit: connect A to B
Old Feb 23, 2010 | 02:30 PM
Hectic's Avatar
You could just go to the junkyard and pull a used one. There's a couple locally, I could get one for you. PM if you want
Old Feb 23, 2010 | 10:42 PM
CMax03's Avatar
I've always called it a hydraulic distribution block... which iMO broke the system down into smaller subassemblies and easier/cheaper too replace during maintenance!
derekinthez
Nov 13, 2022 04:00 PM
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
