Burning Brake Pad Grease
Old May 19, 2010 | 08:35 AM
bvtran's Avatar
94c Big Max
This is like the 10th times I've changed brake pads but why is it every times I put on the anti-squeal greases, that sheet always turn into smoke after the install. Driving around after a new install makes everyone thinks I'm crazy driving around with my wheels all smoking. lol what's going on? Is this normal or am I doing something wrong? I always use those quick easy to use small pouches you get for $2 at Autozone. Could it be I'm using crap grease?
Old May 19, 2010 | 10:14 AM
BenStoked's Avatar
Jesus was a Zombie.
are you putting the grease on the contact pad of the brakes? you should never put any lubricant (or anything, for that matter) between the brake pad and the rotor.
the grease goes on the back of the pad, or anywhere that will move as the pad moves with applied pressure.
Old May 19, 2010 | 10:17 AM
ColombianMax's Avatar
Yea, where ARE you putting the grease?
Old May 19, 2010 | 01:59 PM
Phatmatt's Avatar
Never had problem with grease and brake pads before, and I change tons of them every week. Like the others have said where are you putting it?
Old May 19, 2010 | 05:51 PM
Matt93SE's Avatar
STFU n00b!
Grease? why use grease? just slide the pads in and move on with life.
Old May 19, 2010 | 08:13 PM
nismax1994's Avatar
I use the same stuff on the back of the pads and also use a lube on the moving parts of the caliper. I've never seen smoke. You must be really slapping that stuff on there and it's migrating to the friction surface.
Hatmanafro's Avatar
sad to say it but i agree with you matt
Old May 19, 2010 | 09:27 PM
bvtran's Avatar
94c Big Max
lol I only apply the grease to the back metal supporting plates, not the pad surface itself. Could it be I'm applying too much? I dunno.
Old May 19, 2010 | 10:46 PM
If your front pads are causing for this to happen then chances are they're the only ones doing the work and over heating
Old May 20, 2010 | 04:19 AM
maximagician's Avatar
seized caliper causing overheat?
Old May 22, 2010 | 12:40 AM
i guess we'll assume my reply was too late for him
Old May 23, 2010 | 10:17 PM
bvtran's Avatar
94c Big Max
lol no, it wasn't seized. I just change my pads this time, except I used a lot less and no smoke this time. I'm surprised no one caught that one. Also, the grease pack I used was a lot different this time than the last several times. In the past, I've used the silver crap. This time, I used Silk brand and it looks a lot different than all the one I've used before. It looks like multi-purpose grease. Summary, I just used less and no smoke. That was the answer, magic.
Old May 26, 2010 | 02:45 AM
ok, good i tend to worry about strangers on the internet........
Old May 26, 2010 | 09:41 AM
Matt93SE's Avatar
STFU n00b!
less of it and a different type of grease could both do the trick. Then again I never use that crap and don't have noise issues at all. it just makes a mess and doesn't really do anything.
Old May 26, 2010 | 11:50 AM
Matt93SE's Avatar
STFU n00b!
Hot damn! Hell froze over!
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
