What to replace on New/Used AUTO trans...
Old Jun 6, 2010 | 11:19 PM
Infam0usMax's Avatar
I just got a new/used tranny and before I put it in I want to know what should I replace on/in it...???
Old Jun 7, 2010 | 01:22 AM
ColombianMax's Avatar
Definitely the axle seals with some OEM ones. Check the bottom side of the trans down the middle where there's a split and make sure its not wet/leaking as it seems to be a common spot to leak from. Not sure if the VG has a filter but if it does, I suggest doing that, if you have a VE then def change the filter.
If it's a VG, use OEM Nissan fluid.. I remember Brian once mentioning that aftermarket trans fluid doesnt have the right amount of something, cant remember what but it kills the trans sooner.
Old Jun 7, 2010 | 05:29 AM
Phatmatt's Avatar
The VG does have a filter iirc.
Old Jun 7, 2010 | 11:43 AM
jbbons25's Avatar
It has a filter but it requires unbolting the tranny in half to get to it. Not worth to get to unless you're going to do something else on the inside of the tranny.
And which Nissan ATF is it that's recommended to use? Matic D? I have been using Dexron III the last couple of years. So far no problems but if the Nissan ATF will do better I won't hesitate to switch.
Old Jun 8, 2010 | 01:27 AM
Well, there ya go... change that filter while the tranny is out, even if you have to split it
Old Jun 8, 2010 | 06:34 AM
DanNY's Avatar
Ad·min·is·tra·tor
RE4F02A internal tranny filter...
don't bother changing that unless you want to touch the inside of the tranny.
replace the axle seals.
replace the torque convertor seal.
check to make sure the case is not weeping between the two halfs.
if you like check to see if the torque convertor has enough fluid inside it and replace the TC if needed.
Old Jun 8, 2010 | 11:04 AM
maxinout93's Avatar
What if the case is weeping between the 2 halfs? I think I have a small leak in that area if im not mistaken.
Old Jun 9, 2010 | 12:15 AM
jbbons25's Avatar
You would need to replace the gasket.
Infam0usMax, I thought of something that can be done if you plan to open up the transmission. When the transmission went out on my Max, I got a brake band with kevlar lining so it can last longer since that was the most worn part of the transmission when I tore it apart. I don't know if you can find one around you but that would be one thing to consider.
Old Jun 9, 2010 | 06:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
i would say clean it up w/ some brake cleaner and RTV it. crack the case and lay down a bead of RTV on the mating surfaces. to replace the gasket you'll need to separate the two halves and clean it up and then put it back. at that point might as well rebuild your busted tranny.
Old Jun 9, 2010 | 06:09 PM
Reizy's Avatar
Not on the tranny but how about the rear main seal?
Old Jun 9, 2010 | 06:14 PM
ralf0214's Avatar
i think you should work on it
Old Jun 9, 2010 | 11:16 PM
maxinout93's Avatar
Which gasket, and can the gasket be replaced with the tranny still in?
Old Jun 10, 2010 | 10:32 AM
DanNY's Avatar
Ad·min·is·tra·tor
if there's 10K or more on it then swap that out too.
Old Jun 10, 2010 | 10:34 AM
DanNY's Avatar
Ad·min·is·tra·tor
there's a gasket between the two halves of the tranny (where you said ATF is weeping from).
you need to unbolt all the bolts around the case and CAREFULLY lift up a little on the top half and clean and squeeze in some RTV.
no tranny NEEDS to be out of the car.
Old Jun 10, 2010 | 11:29 AM
maxinout93's Avatar
Ok thats great, I will try that.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
Cotozic
Jun 28, 2017 08:01 PM
Maxilano
Aug 31, 2015 07:33 PM
KristyKarina
Aug 23, 2015 09:53 AM
