BEST Struts...and yes i searched.....
Old Dec 13, 2001 | 10:27 AM
ObsidianIce69's Avatar
I am looking to see what the best struts are for a 3rd Gen Maxima. My struts are shot and i want to replace them with something good. I do not want a bone crunching ride, but i need my Max to handle VERY good. I'm tried of the floaty ride of a GXE, so i want to know which strut will give me great handling (car will see track time) and also a "decent" ride.
Old Dec 13, 2001 | 10:43 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: BEST Struts...and yes i searched.....
Low to high in $...
KYB
Tokicos
Koni
you didn't search hard enough.
Old Dec 13, 2001 | 11:03 AM
Re: Re: BEST Struts...and yes i searched.....
Originally posted by DanNY
Low to high in $...
KYB
Tokicos
Koni
not worried about the money really, i'll spend to make sure things are done right, but you're saying the Konis are better than the the tokicos?
Old Dec 13, 2001 | 11:15 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: BEST Struts...and yes i searched.....
koni are adjustable...the other two are not.
Old Dec 13, 2001 | 02:37 PM
Neice Anne
Re: Re: Re: Re: BEST Struts...and yes i searched.....
Aren't Konis the best handling-wise too? Well to Obsidian yes get Konis if money ain't a thang
Old Dec 13, 2001 | 04:07 PM
latinmaxima's Avatar
Re: Re: Re: Re: Re: BEST Struts...and yes i searched.....
koni's are nice because they are adjustable but if you won't be messing with them then tokico's are just as nice.
Old Dec 14, 2001 | 04:25 AM
LOL, i wouldn't say money ain't a thang, but i have a friend who can get me hookups on parts...
Old Dec 14, 2001 | 06:13 AM
So don't pick Kyb Agx?
I noticed that no one recommended the kyb agx struts. Why not? Are they that bad, or are the koni's just that much better?
Old Dec 14, 2001 | 06:29 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: So don't pick Kyb Agx?
KYB AGX's aren't available for us...only the GR2's...they are an OEM replacement and not a "performance" strut
Old Dec 14, 2001 | 05:00 PM
John van de Pol's Avatar
Struts
Konis are second to none, and barring failure which some have reported (warranty) they will not wear out like Tokicos will. My Toks, with a stretch, lasted 40K miles. Konis should last the life of your car.
John
Old Dec 14, 2001 | 07:05 PM
amax935's Avatar
struts
the konis fronts are not direct bolt ups like the other 2. the old fronts have to be customed to fit the inserts in. also chances are the koni's may be harder to get ahold of. it seems like every time i check with shox.com, they are backordered from holland.
Old Dec 17, 2001 | 07:22 AM
Ok, thanx for the advice! Looks like i will definitely be getting the Koni's now!
Old Dec 17, 2001 | 07:49 AM
Maximum5spd's Avatar
Whatever you do DO NOT GET TOKICO, I had them for less the 15k, they are already warned out and make funny noises. Konis are awesome, theyre lil expensive, but trust me its worth the money.
Old Dec 17, 2001 | 09:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
what springs do u run?
Old Dec 17, 2001 | 11:15 AM
Well i still have those tokicos in the front and konis in the back
Old Dec 17, 2001 | 11:29 AM
hmmmm, so Koni struts and eibach springs sounds like a good combo?
Old Dec 17, 2001 | 11:31 AM
DanNY's Avatar
Ad·min·is·tra·tor
right those are your struts...what >>springs<< are u running?
Old Dec 17, 2001 | 12:18 PM
eibach
Old Dec 17, 2001 | 05:09 PM
i just was wondering if it was a good idea to have diferent springs in front than in back. i have already ordered the koni struts and i have a friend who has a back set of eibach's but they only lower it about 1.25 on the stock struts which still looks good but i would like the front lower. is that a bad idea?
Old Dec 17, 2001 | 05:24 PM
Mr. Nismo's Avatar
Yes, that's the best way to go for struts and springs.
Old Dec 17, 2001 | 06:17 PM
Booner8269's Avatar
So what are the proces for some Koni struts and Eibach springs, so the bearing plates come with them?
Old Dec 17, 2001 | 06:22 PM
Bman's Avatar
I'm no expert, but I don't see why not. The stiffer rear springs will reduce understeer just like adding a RSB (almost). So I don't really see a mechanical reason why not to do this. I don't know if a 1.25-1.5 inch drop in the rear should warrant you aiming your headlights a bit lower...
The only thing is it might look a bit off kilter with the front slightly higher than the rear. Some of our cars do this already I think (called "saggy @ss syndrome" or something), due to sagging springs. But if you don't mind the look, then I think it'd be alright.
Old Dec 18, 2001 | 05:45 AM
I have another question about struts, this may be stupid though but bear with me, do i ned to replace all 4 at one time? Could i replace the front and then do the rear later? Or would it be better to just replace all 4 at the same time?
doolstersmaxima
Jul 21, 2004 10:21 PM
XeroX
Apr 30, 2004 09:45 PM
