Affordable Injectors?
Old Jul 19, 2010 | 06:18 AM
gapboi210's Avatar
I am guessing I have a bad injector. After the engine warms up. I get a dead miss. I believe cylinder number 5, back of engine, closest to driver's side? Anyways if I disconnect that sparkplug boot, no change in miss, have spark. I pulled the injector connection and with a test light, I have a steady hot with a pulsating ground. So I am guessing a dead injector or one that is getting weak with heat.
Anyone know a source for cheap but decently reliable injectors?
PS I am a pro at taking the intake off and on.
I have had to take it off for:
1. replace fuel lines
2. replace fuel lines again (advance sold me low pressure fuel line)
3. replace fuel injector pigtails
Old Jul 19, 2010 | 06:42 AM
BenStoked's Avatar
Jesus was a Zombie.
internetautosupply.com; new cheap.
don't go with remans, blah blah blah.
Old Jul 19, 2010 | 06:55 AM
gapboi210's Avatar
from what I have read our injectors are not rebuildable. So any that say they are, are just cleaned. Is this right?
Old Jul 19, 2010 | 07:01 AM
gapboi210's Avatar
Also internetautomart prices seem to be the same as everywhere else. I am looking at RockAuto.
BECK/ARNLEY Part # 1580654 $89.79
Old Jul 19, 2010 | 09:33 AM
James92SE's Avatar
2 VE's are better than one!
Correct.. although they probably have new pintle caps though
Old Jul 19, 2010 | 10:21 AM
maxitech's Avatar
Bosch is the way to go.
If you need to be on the cheap go to the junkyard.
Old Jul 19, 2010 | 10:32 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yep. and that does nothing to prevent the wire from corroding, which is what causes them to ohm out of spec. possibly due to the presence of 10% ethanol in gas nowadays that the wire wasn't coated to resist? who knows.. but it's pretty well documented that the wire coil deteriorates.
Old Jul 19, 2010 | 12:35 PM
gapboi210's Avatar
Yeah mine seems to fail mostly when the engine is hot. I think a reman would be better than a junkyard one. At least it would be clean and have some sort of warranty. I just OHM'd it not too long ago too.
Old Jul 19, 2010 | 07:42 PM
zakmeeks's Avatar
i usually find a j30 or something and at pullapart for 7.50 a pop. all the maximas are missing them although i got a clogged one, wierd, and had to pull the manifold again to replace. it had good impedence and fired, but nothing came out lol.
Old Jul 19, 2010 | 07:57 PM
James92SE's Avatar
On the VE, there's actually a ton of Nissan's that have the same injectors, so I always grab what I can
All 4th gens, J30s, 97-01 Q45's, 91-99 Sentras, 93-97 Altimas, 91-97 240s, etc.
Old Jul 19, 2010 | 09:49 PM
gapboi210's Avatar
I have a VG though with the square EV1 connectors.
Old Jul 20, 2010 | 05:22 PM
zakmeeks's Avatar
those are easy to find. almost all the 90's sohc 4 bangers have em. although the 240 kids usually grab them all
Old Jul 21, 2010 | 11:11 AM
gapboi210's Avatar
again, I still think getting reman one that has been cleaned and has a warranty for $38.00 would be better than trying the JY right?
Old Jul 21, 2010 | 11:53 AM
BenStoked's Avatar
Jesus was a Zombie.
what kind of warranty 30 days? 90? does the warranty include the cost of new gaskets when you disassemble everything?
you can ohm-test an injector before pulling at a junk yard... that seems to be a pretty good warrany, imo.
and flow is usually not the problem, as said before.
and again, there is no such thing as a "reman" vg injector.
Old Jul 21, 2010 | 06:30 PM
maximo018's Avatar
Tell me, does your car start to shake/vibrate badly at all when it starts missing? Reason I ask is my symptoms are similar. So I'm glad you made this thread before I did. Now I know exactly what I have to do even though I dread going back in there but I know what it is now.
Old Jul 21, 2010 | 09:26 PM
CMax03's Avatar
2 of mine failed and was cause by failure of the windings....open/infinite!
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
