Need some ideas...
Old Jul 22, 2010 | 12:00 PM
xX4DSCXx's Avatar
Need some ideas...
ok so im attempting to install a gps in my dash and i need some ideas on how to turn the gps on, it turns off by it self when you turn the car off. ive been trying to think for a month and my ideas havent worked.
Old Jul 22, 2010 | 12:02 PM
James92SE's Avatar
2 VE's are better than one!
Link doesn't work
And wait, you want the GPS to stay ON when the car is off?
Why can't you just connect it to constant power?
Old Jul 22, 2010 | 01:23 PM
akurtzer57's Avatar
Just run the hot wire into the acc switch on the ignition and the ground just to chassis sum where.
Old Jul 22, 2010 | 04:54 PM
xX4DSCXx's Avatar
Link doesn't work
no i want the gps to turn on when i turn the car on. it turns off when i turn the car off.
Old Jul 22, 2010 | 04:56 PM
xX4DSCXx's Avatar
that sounds like a good idea! ill have to try it.
Old Jul 22, 2010 | 05:59 PM
Cmaxima's Avatar
Just tap into 12V from somewhere, just like hard wiring a radar or something
Old Jul 22, 2010 | 06:20 PM
Matt93SE's Avatar
STFU n00b!
Pull radio out of dash, tap into yellow/green wire. That's the accessory power wire that switches the radio on and off. that'll work perfectly for the GPS.
Old Jul 22, 2010 | 06:31 PM
xX4DSCXx's Avatar
will that turn it on though? because when you plug it into external power it doesnt turn on by itself, you have to push the power button. when it losses external power it automatically turns off.
Old Jul 22, 2010 | 07:24 PM
James92SE's Avatar
Are you saying your actual GPS unit itself won't turn on AT ALL without you manually pressing the power button? And you want to somehow wire around that on the car side?
If so, you may be SOL. I mean, if that's how your GPS is designed you'll probably always have to push the power button. If you don't like that function of your GPS then you should probably get a different GPS.. unless you want your GPS "always on" even when your car is off, but that's probably not smart in terms of battery drain
Old Jul 22, 2010 | 08:48 PM
nyc_ink's Avatar
10+ imma try something with this idea. if it works imma let u know. thanks
Old Jul 22, 2010 | 08:53 PM
xX4DSCXx's Avatar
yea thats wat im saying.
ok thanks for the help.
Old Jul 22, 2010 | 08:56 PM
nyc_ink's Avatar
heres a pic of it so far.
http://sz0009.ev.mail.comcast.net/se...d=27782&part=2
just get a flip out screen and put gps on it bro, dont bother making your own cuz some dude did it and it looks like crap cuz the plastic is all melted n all that shet. unless u make a custom center piece and switch locations of the things but that'll cost more than just buying what i said.
Old Jul 22, 2010 | 11:16 PM
jvc1986's Avatar
If the GPS has a "real" power button (not the touch type like the PS3) you can probarly open the unit, solder on 2 wires between the 2 contacts of the power button, run them through a relay, connect the relay to ACC or the yellow/green wire.
So that the relay wil engange when car is started, and power on your gps.
If the power button is just a touch type, this probarly wont work
Old Jul 23, 2010 | 08:12 AM
Cliff Clavin's Avatar
Way out West
It would probably be easiest to ebay your current GPS and buy another one that turns on when you give it power.
I got a Nuvi widescreen (255w? I don't have it in front of me) for under $100 including shipping on ebay a few months ago. It turns on automatically when you power up the car. When you turn off the car, it asks if you want to continue on battery power or turn it off.
Old Jul 23, 2010 | 08:19 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yep i have the same one. pretty nice once it grabs onto a signal. but if you turn it off, drive 10 miles, and turn it back on it takes a few minutes to figure out where it is.
Old Jul 23, 2010 | 11:57 AM
xX4DSCXx's Avatar
yea i saw his, and beleive me mine looks so legit, it looks stock. once i get it in ill post some pictures!!!
thats a really good idea!!!! thanks bro!! ill have to try it!
Old Jul 23, 2010 | 12:15 PM
ColombianMax's Avatar
thanks for your honesty on an unfinished mod
Old Jul 23, 2010 | 12:52 PM
nyc_ink's Avatar
lmao that was you?
mah bad
Old Jul 23, 2010 | 12:57 PM
nyc_ink's Avatar
i was talking bout this one, so it wasnt u after all colombianmax lol
lemme see ur's
http://forums.maxima.org/1st-3rd-gen...trol-unit.html
Y2k2maxse
Oct 20, 2009 05:56 PM
C-Young
Jul 10, 2009 07:13 PM
PARALLEX
Jun 28, 2006 12:25 PM
