Bose radio wont play
Old Aug 12, 2010 | 09:32 PM
G3Karl's Avatar
My bose radio will not stay on. It turns on then turns right off. I hear a click under the dash when trying to turn on the radio. It will play for a few seconds here and there. Anyone know if this is a quick easy fix? Thank You!!!
Old Aug 13, 2010 | 04:44 AM
Hectic's Avatar
Grab a junkyard deck or buy an aftermarket one that will blow away the bose. Upgrade your speakers and bypass the amps though or you risk the 1 ohm load blowing away your deck's amp instead . Unlikely, but it will put un-needed strain on it.
Old Sep 4, 2010 | 09:33 PM
mejoralex's Avatar
I have the exact same problem, but the stereo is no longer working.
Old Sep 4, 2010 | 10:36 PM
maximus53172's Avatar
I've got a used Bose unit out of a 04' Max. I'm looking for $40 plus shipping. Let me if this helps, thanks.
Old Sep 5, 2010 | 05:01 AM
Hectic's Avatar
If it helps, I will let you.
Old Sep 6, 2010 | 03:26 PM
gladiator's Avatar
are all the wiring / harness the same? 94 and 04?
Old Sep 6, 2010 | 04:21 PM
James92SE's Avatar
2 VE's are better than one!
Old Sep 8, 2010 | 07:19 PM
DennisMik's Avatar
NO, you need harness adaptors. Plus the faceplate of the 2000 and newer headunits are curved - yours is flat. You can put in a 4th gen headunit, but you'll need the wiring adaptors.
Old Sep 8, 2010 | 09:07 PM
ColombianMax's Avatar
+1
chisam14
Nov 6, 2018 08:56 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
